Plexify | OS X Application
We don't want to give bad program, we don't want that you had problems, everything has to be perfect
I'm sure you wouldn't!  To paraphrase Voltaire "Don't let the perfect become the enemy of the good"
Even 1.0 is perfectly usable for me, the improvements in 1.x will be icing on the cake.
This is just superb work, thanks so much. Working nicely and for the time being I'm not too bothered about the password issue since that looks as if it'll not be a problem when 1.1 comes out.
I slightly modded the grey icon to be a little sharper like the black icon that was posted here earlier, hope no one minds.
One question I do have - I'm going to be installing all this on a friends system. Can I use a copy of my own .pem file to install on her ATV or do I need to create a new one on her Mac?
I love this program. Well done guys! At least now my wife will understand what to do . It was it bit too complicated to get her to understand Terminal. Looking forward to all the new features in 1.1.
Another feature i just thought of, that after all the other features and this one will be in the app it'll be PERFECT:
Option to change the app PlexConnect will Hijack-I mean, it's possible to use PlexConnect with Trailers, iMovie Theater, WSJ Live and probably more. So you can create an option for this in settings, and every app you'll choose the Plexify app will change PlexConnect files to the right Domains and will do that automatically with every Github update!
Thanks for the good effort! Appreciated :)
If you truly trust your friend go for it. Sharing pem is a security issue.
Sent from my iPhone using Tapatalk
This is what I've been looking for, great!
But I don't know if I have the correct download...I see some cool icons here for in the menu bar, but my app still has the black circle as icon.
It's a bit confusing, having two download links on the main page. Do I need the PlexConnect.app? Or the PlexifyAPP.app?
Kind regards,
Chris
Hello.
Thank all for waiting new version.
Its not simple - many major changes
Cyberon works day and night, doesn't eat, doesn't sleep  :D  :D  :D
Kind regards,
Chris
Only one link - DropBox - PlexifyAPP
New cool icons its a new version
I think if you see it - you will fall from a chair  :D
Ok, so we are still awaiting a new version?
The download link on DropBox says it's 5 days old.
YES!  :D
ok guys, some good news. Just finished the development part. Give us a few hours (well, maybe a little bit more) to test the app.
We need testers, testers and testers.
I'm not sure if it's compatible with 10.6. Please don't yell if it's not.
Tester here 10.9 :slight_smile:
Can you upload the app as a zip file here so we can download & test it? I sent you a private message as well.
Happy to test the new app for you. I'm on 10.8.4.
@rescph2, @wahlman.j and @brett05
I'll send you zip file and details of how to test soon. Thanks.
@cyberon - i can test on a 10.6 machine and a 10.8.5. i'd love to support to see it work on a 10.6, so that my parents can use it.
Tester here, 10.7, 10.8 and 10.9
tester for 10.8.5
