Hi there, working much better for me now with 1.0.7, thanks
I did a fresh install of kodi & plugins on ubuntu 14, after it ran the scan it said “Sync had to skip some items because they could not be processed. Please post your Kodi logs to the Plex forum.” pastebin.com/1CVsLdwh thanks
@croneter said:
@sylus said:
Great update. With 1.0.7 I finally can connect. However, not via PIN just via localhost. It is no problem for me but maybe for others.Could you elaborate?
- What exactly is not working, at which point of the setup process?
- PMS in the same network or remote?
- PMS and kodi on the same PC?
- is your PMS signed in to plex.tv? (reachable from the outside)
- logs please
Connection via the help of https://plex.tv/link is not possible, eventhough the page confirms that the app is connected and can be used via Plex. After changing the connection to localhost the app connects fine and I can select the user. Sync starts then without problem. Only the automatic connection via PIN is not working.
- PMS and kodi are on the same PC
yes, my brother can connect via Samsung TV Plex (with PIN) just fine.
when the App started to sync i closed kodi, so these aborts are related to me and not to the Addon
@Silvaire said:
@croneter said:
@Silvaire said:
Good news: On a fresh OpenElec I got everything syncing and working great. There was some odd flickering behavior going on on my home screen after playing something through a widget, then stopping it and going back to the main menu. It went away after 3-4 pulses.Bad news: I broke the installation by trying to set up multiple users. I set up a new Kodi profile for my wife and it crapped out the addon for both my wife’s profile AND mine.
Could you also elaborate please?
- logs please
As soon as I log into the secondary profile, the addon just says “error”. When I log into my master profile, it is also not connecting. Nothing will play. I believe it has something to do with Kodi profiles and trying to have addons with dif settings for dif users. In PlexBMC, I used the addon itself to switch users and could never get Kodi profiles working.
No, PMS is on a local LAN.
Yes
Working on logs, having some difficulty locating the relevant ones on openelec this time around. Will try to reproduce and log.
UPDATE: Can confirm reboot fixes master profile. But logging in the secondary profile will break addon for both users until reboot.
So you are talking about Kodi profiles, not plex ones? Never tried these ![]()
- logs please
Yes
No worries, I thought that was how we were to setup a multi-user environment. If there is a ‘switch user’ option in the addon, I can just bind that to the main menu and hopefully it’ll work. Will let you know. Thanks so much! This addon is going to get me serious WAF points!
Ok, I tried using the ‘switch plex user’ functionality in the addon itself instead of using 2 dif kodi profiles but it also doesn’t work.
Just gives me the ‘are you sure you logged in’ error when I try to switch users so as of now the addon does not support multi users I think.
@Silvaire said:
Ok, I tried using the ‘switch plex user’ functionality in the addon itself instead of using 2 dif kodi profiles but it also doesn’t work.Just gives me the ‘are you sure you logged in’ error when I try to switch users so as of now the addon does not support multi users I think.
Works here. Logs please ![]()
Bingo !
- home user works even with plex.tv link
- sync just one reboot - a hint as popup would be nice…
Thank you !! you are my man - great stuff !!
When you say “restart” do you mean to restart the kodi.exe or the plexserver.exe??
@Monstar316 said:
Anyone else having issues with artwork not showing for TV Shows? All poster/thumbs are appearing for Movies and Music but not for TV Shows. I’ve tried different skins, re-install of PKC but still nothing.Would it be safe for me to delete the databases manually and start again? If so, which databases are populated by PKC? It’s for an Ubuntu 14.04 OS.
Has this been addresses at all? I can’t seem to find anything. Fresh install of everything - Kodi 16 - PCK 1.0.7. Initial scan worked perfectly but no season posters in TV shows at all.
Fixed on reboot. Not gonna question it.
However, is there a way to make the switch user function more elegant and faster? It takes 5-7 seconds to switch, and then another 1-2 seconds while on the home screen before widgets change. In terms of elegance, when I bind ‘switch user’ from the plugin to the menu, and click on it, it does not take me straight to a switcher pop-up, it takes me to the root tree of my PMS in the addon and if I wait 3 seconds, the switcher pops up. I hit a user, and then wait 2 seconds for it to login, and then I have to manually back out of the addon back to the home screen.
What would be ideal is either having a ‘switch user’ node from skin main menu go directly into the account chooser, and upon choosing an account, immediately take you back to the root main menu of Kodi OR be able to bind the ability to switch to user A, B, C directly from a command that can be bound to a remote.
I have the same issue. In season view, posters do not load.
Here’s an interesting observation. If I have Kodi library view open showing a list of movies and I access PMS on another device, if I mark a movie watched on PMS, Kodi updates instantly (along with the 10 seconds of mini pop up messages as always). If I do the opposite and mark an already watched move as unwatched on PMS, Kodi does not update. Of course this is not something we would be doing on a regular basis but it does show a sync issue happening.
same here
Always restart Kodi. I never had to restart the plex server
Refer to below
@mini.PLEX said:
same here
I installed PKC onto a fresh install of Kodi on an Ubuntu 14.04 Virtual
Machine but same issue; no artwork for tv show season posters.
I have also noticed that my music files aren’t showing but the artwork,
folder structure are all there.
Movies are all good.
Ok I lied, appears movies are fine, but TV shows are not showing any seasons. FYI, I have five ‘libraries’, TV, Movies, Kids TV, Movies and Documentaries.
Log here: redacted
New version is out: Releases · croneter/PlexKodiConnect · GitHub
Incremential background sync should now update your Kodi library in seconds. Any “screen flashing” that you’ve experienced should also be a thing of the past (happens only if you actually change a PMS item).
As a sidenote - since you’ve started complaining about missing TV season posters, I guess PKC is running pretty stable
##Changelog##
version 1.0.8
- Redesigned fast incremential sync
- Workaround to sync Kodi time with PMS time
- Fix library sync key error
@croneter said:
New version is out: Releases · croneter/PlexKodiConnect · GitHubIncremential background sync should now update your Kodi library in seconds. Any “screen flashing” that you’ve experienced should also be a thing of the past (happens only if you actually change a PMS item).
You are really incredible! =D>
I can confirm that the flashes are completely gone and syncs happen instantly in both directions!
I think so too ![]()
How do you guys handle the different movie sections from PMS with PKC?
For example, I have a “Movies” section and a “Test Patterns” section on my PMS, after a scan with PKC in Kodi, those sections are merged - ie. if I choose “Recently Added Movies” in Kodi, it shows both my Movies and Test Patterns, which is not what I want
