PlexKodiConnect: Kodi Plex Integration Done Right
Well, for the moment I don’t have other album to add, but as soon as I do one I will post the logs on github ;D
By the way, can you have a look in this topic ?
Thank you
@JDWL said:
Hi all, apologies if this has been asked before, what is the preferred Direct Play setup for a Local plex server - eg; Kodi, Plex and all the media are on the same machine?
I’ve set up the direct paths using SMB on my htpc / service (Ubuntu 16.04) but am unsure whether this is the most efficient PKC setup when everything is on the same machine.
Thanks,
Just use the same SMB setup as on your other Kodi machine where Plex is not running
@plexonweb said:
  1. Why are Plex collections stored in BOTH sets and tags. It would be much cleaner if Plex collections were only in sets and the PlexLibrary names only in Tags.
There’s a TON one could improve. Open a new feature request please: Feathub.comfeathub.com | Tempat rekomendasi situs judi online terbaik dengan bonus yang beragam dan terpercaya
@plexonweb said:
2) Can you add the PlexLibrary name as an ‘album genre’ to music files when they are imported, in the same way as tags are added to movies. Then we can create nodes based on these to separate out the plex music libraries (same as movies/tv currently do with tags), as currently they appear as one big blob. I tested this out by manually adding them in Plex but it’s not practical to do this every time new media is added. Maybe Moods or Label could be used instead but Genre is only field available in Plex UI that is suitable.
e.g: I added genres plex-movies, plex-movies.kids, plex-movies.doc. It could be an optional feature and could use plexserver name as prefix to handle multiple plex servers.
Good idea actually! Please open another feature request :wink:
@croneter said:
@petree said:
Hi! Love your plugin, works like a charm!
I just have one problem. I’m using kodi 18 on a raspberry pi 3 (Milhouse build) and when I try to cache all images to kodi (lovely feature) the library thread crashes. Same thing on my odroid c2. It does however work on my mac and kodi 17 on all devices.
I know that kodi 18 is not officially supported, I just wanted to submit the problem and if you could solve it, it would be a bonus.
Share your logs and I will have a look. See How to Report A Bug · croneter/PlexKodiConnect Wiki · GitHub
My log file is around 1 mb, don’t know how that happened, massive PKC failures… Where can I upload such a large log file?
Just attach it to the github.com issue directly. Remember to delete all the tokens first
I’ve just realized that, with the latest version 1.8.17, the context menu is missing and i cannot delete my episodes or movies any more. How can i delete my watched files from Kodi without going to plex server and manually delete them?
Tgx
Tgx
same here
@Tgx, @Nat
Urgh, noted, sorry guys!
Should all be good now with version 1.8.18
Changelog
version 1.8.18:
  • Russian translation, thanks @UncleStark, @xom2000, @AlexFreit
  • Fix Plex context menu not showing up
  • Deal better with missing stream info (e.g. channels)
  • Fix AttributeError if Plex key is missing
@croneter said:
@Tgx, @Nat
@croneter said:
@grooves12 said:
I have recently started having an issue where files that are watched on Kodi are not having their progress and watched/unwatched status tracked properly. Shows I have just finished watching will remain showing as unwatched in Kodi. I have to manually change their status and even when I do that it does not change immediately.
When did that start, approximately? Are you using PKC version 1.8.17? Have you tried rebooting kodi just to be sure? Have you tried another skin?
It started about 2 weeks ago…
I am on PKC version 1.8.18 now… it is set to auto-update. I’ve tried rebooting Kodi and Plex Server, behavior is still the same.
I am using the titan skin and have not tried a different one yet.
Please try another skin like estuary, quickly fast forward to the end. If the issue persists, I need a kodi debug log: How to Report A Bug · croneter/PlexKodiConnect Wiki · GitHub
Yea this is F*CKING AWESOME!
Hope this assists someone else, I was getting this error in my Plex log every 2 seconds while playing media:
ERROR - Unable to find client profile for device; platform=Linux, platformVersion=, device=PlexKodiConnect, model=
I created a PlexKodiConnect.xml profile in the Profiles directory, which is a copy of the Generic.xml:
<?xml version="1.0" encoding="utf-8"?>
Errors stopped immediately and time to play reduced.
Thanks, that helped to reduce loading times quite significantly
I get the same profile error so tried the PlexKodiConnect.xml but I get the following error…
ERROR - XML: Start tag expected, ‘<’ not found
And “ERROR - Unable to find client profile for device; platform=Linux, platformVersion=, device=PlexKodiConnect, model=” , still shows in the logs after a restart.
Any idea why that is?
Edit: Never mind… On Ubuntu the profile needs to be in
“/usr/lib/plexmediaserver/Resources/Profiles/”
not in…
/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/
No errors now! Many thanks.
can anyone help i got plexkodiconnect up and running working exceptionally well better then the first time i tried it. but episodes has no thumbnail :frowning:
Need a bit more info
  • What Kodi skin are you using?
  • Have you tried using another skin than the current one?
  • Try going to the PKC settings, Artwork, “Download Artwork now”, then let Kodi sit for at least 60 minutes
@croneter :
  • If I install PlexKodiConnect, default installation, works great. But playback is delayed. When using PlexBMC it is alot faster to actually serve the video
  • I try to setup directpath playback, but I since my server is offsite, via seedbox, I assume this is not possible?
