@hstamas said:
Sorry if this is a known issue but I’ve been away from PKC for a bit. Is there any reason PKC won’t install on a Nvidia Shield running SPMC Jarvis 16.7?I can install the repository but the plugin itself comes up as incomparable?
Has something changed since I’ve been away?
Update: Oddly, the act of enabling debugging in Kodi allowed me to install the plugin. I was however not able to do it through the repository. I had to download and install locally.
I had to move the repo as they suddenly blocked Kodi altogether. It’s now on github.com directly. Seems like Spmc does not like that for some reason. Unfortunately I cannot test with Spmc. Could you be so kind and share some debug logs of you trying to access the PKC repo? Issue is already on github.com: Repo is empty when attempting to install on SPMC · Issue #390 · croneter/PlexKodiConnect · GitHub
