Alternatively, if you’re lucky, your different folders of the same type are all within the same “master folder”, e.g. /media/movies/ for /media/movies/4k and /media/movies/other-movies. Simply ONLY choose the master folder in PKC path settings, e.g. /media/movies
Any suggestions why when using the plex app to cast to a kodi device running plexkodiconnect When I play a album the first song seems to immediately restart. then it will play through the end and start over. After that the rest of the album will play properly.
Question, does your PlexKodiConnect/Kodi refresh immediately what has been recently added? Or do you have to restart Kodi to see recently added? My background sync seems to not function.
For PKC background sync to work, you need to use a Plex Home master user - this is due to limitations on the Plex side, unfortunately. Workaround that might help you: reduce the time between full syncs in the PKC settings.
I cannot reproduce your issue. I do get a new, unique device ID. Could you try again and share your DEBUG Kodi log file as explained here? It should tell me e.g. if the new ID is identical to the old one
I don’t know if I’m Plex Home Master. But I am server administrator. Will that work or do I have to buy Plex Pass? Have not had time to test with server administrator user. Waiting for version 2.5.0
I searched everywhere in Kodi & in PKC settings, tried many combination but I always have a very annoying error each time I try to enter an album, list, playlist… etc in the Music section of Kodi.
The error is “Music Library needs to rescan tags from files. Would you like to scan now ? Yes / No”.
I tried Yes, No, Add-on Path, Direct Path, reset config, restart install from scratch… nothing made this error message to disappear. Music plays fine but the error message is always present.
I’m using Direct Path.
Can anyone help me before I become crazy ?
Thanks !
PS: my setup is PKC 2.4.9 on Leila 18.0RC1 (Build 20181103)
Have you tried using Kodi 18 Beta 5 instead of the nightly RC? Lots of stuff changes and potentially breaks with nightlies, so no PKC support there, sorry
is it possible to let PKC create .strm-links in an (i.e.) network share? I use some addons (Amazon Prime Video and Netflix) to create such links for library integration. So when I manually update the library, Plex enties are gone (sometimes) and I had to rerun the whole import process. When I have a additionally folder (share maybe) with the Plex .strm-links, this shouldn’t care. Maybe a thing for version 3.0?
I have android box with Leia beta5 and plexkodiconnect. When I run KODI it is about 30s waiting for plexkodiconnect to log in and then when I press play for movie, again waiting for movie to begin 30-40s.
I think this is too long. My PMS is on my home network on windows and I am using add-on with direct play for plexkodiconnect.
