PlexKodiConnect: Kodi Plex Integration Done Right
Latest one. Do not use nightly versions tough
LibreELEC (Leia) v8.95.1 BETA was released today so I will upgrade to that.
Based on RC3 so hopefully it will be supported?
Biggest problem is resume position not updating when starting and then stopping a video. It resumes from the original position rather than where I stopped it.
I cannot reproduce your issue. Please open a new issue on Github and provide more information, e.g. debug logs
I’ve always had problems resetting resume positions in kodi and having that change sync to plex. The next time pkc syncs the resume position resets.
I also posted a new issue on github with the database being locked.
After wiping and reinstalling everything, the error persists.
However if I install PKC 1.8.18 the error disappears once again, update to any other recent release of PKC and the following error returns.
I spent considerable time trying to resolve this by changing permissions, reinstalling Plex, Kodi and Ubuntu, thinking it was something in my setup. But it appears to be some change in the code perhaps between versions 1.xx and 2.xx… For now, I will stick with 1.8.18 for no other reason than it does not write an error to the log every 2 seconds.
Merry christmas!
Changelog
version 2.5.8 (beta only):
  • Hopefully fix Kodi crashing on playback start
  • Fix video resuming from old resume point
  • Fix database is locked
  • Faster way to initialize playlists on the Plex side
  • Fix PKC recreating playlists too often
  • Shutdown playlist sync if necessary
@croneter
I have put my problem at the link below in case you are interested.
Hi @croneter!
I have no complaints, just wanted to give you some cred for an awesome addon!
Thanks a lot for your effort and contribution!
PKC is fixed! Christmas is saved! Thank you @croneter happy new year! :slightly_smiling_face:
Thid happens with PKC on Kodi 18 RC3 on Nvidia Shield as well…
Can anyone confirm the ‘play next’ row in android oreo is working with kodi 18/PKC on Android TV? If so what settings are you using in PKC, direct paths?
Play Next example:
So, Kodi 18 RC4 is out and they changed the database version. I noticed that the beta version of PKC has already been updated to be compatible but what about the stable version?
There is one major bug yet preventing an update of the stable version. PKC beta also yet needs a small update for compatibility with Kodi 18 RC 4Stay tuned.
If I’m interpreting your response correctly I’m better off staying with RC3 until PKC is ready for RC4.
Is this correct?
Correct, as PKC is not yet compatible with RC4
Any ideas as to why I can’t seem to update past 2.4.10? It’s the latest version that appears in the repository when using 1.0.2 of the beta.
Any help most appreciated!
No, need more info. Please share your logs as described here: How to Report A Bug · croneter/PlexKodiConnect Wiki · GitHub
Apologies for that. My log file is available here; https://pastebin.com/6YjTvS4M
Thanks! Seems like you somehow botched your Kodi install. Kodi seems to hang trying to update a single other addon:
18:33:28.891 T:3505124080   ERROR: AddonVersion: 9-g8b77776 is not a valid revision number
18:33:28.892 T:3505124080 WARNING: Repository add-on repository.aussieaddons-devel uses plain HTTP for add-on downloads in path http://aussieaddons.com/repository-devel/ - this is insecure and will make your Kodi installation vulnerable to attacks if enabled!
18:33:28.921 T:3505124080 WARNING: Repository add-on repository.xbmc.org uses plain HTTP for add-on downloads in path http://download.osmc.tv/kodi/addons/leia - this is insecure and will make your Kodi installation vulnerable to attacks if enabled!
18:33:28.930 T:3505124080   ERROR: AddonVersion: 9-g8b77776 is not a valid revision number
Try to delete the addon script.module.drmhelper v1.1.0-9-g8b77776
