@jaydash
You got some errors that seem unrelated to PKC:
DEBUG: Skin Helper Service --> MainModule called with parameters: {'action': 'setkodisetting', 'setting': 'lookandfeel.skincolors', 'value': 'SKINDEFAULT'}
ERROR: JSONRPC: Failed to parse '{"jsonrpc":"2.0", "id":1, "method":"Settings.SetSettingValue", "params":{"setting":"lookandfeel.skincolors","value":SKINDEFAULT}}'
DEBUG: JSONRPC: Value does not match any of the enum values in type
DEBUG: JSONRPC: Array element at index 6 does not match in type properties
DEBUG: Metadata and Artwork module --> {"error":{"code":-32602,"data":{"method":"AudioLibrary.GetAlbums","stack":{"message":"array element at index 6 does not match","name":"Item.Fields.Base","property":{"message":"Received value does not match any of the defined enum values","type":"string"},"type":"array"}},"message":"Invalid params."},"id":1,"jsonrpc":"2.0"}
DEBUG: Metadata and Artwork module --> {'params': {'filter': {'and': [{'operator': 'is', 'field': 'album', 'value': u'Wood'}, {'operator': 'is', 'field': 'artist', 'value': u'Widespread Panic'}]}, 'properties': ['title', 'fanart', 'thumbnail', 'genre', 'displayartist', 'artist', 'genreid', 'musicbrainzalbumartistid', 'year', 'rating', 'artistid', 'musicbrainzalbumid', 'theme', 'description', 'type', 'style', 'playcount', 'albumlabel', 'mood', 'dateadded']}, 'jsonrpc': '2.0', 'method': 'AudioLibrary.GetAlbums', 'id': 1}
Have you tried resetting the Kodi database in the PKC settings under Advanced? (hitting YES, then NO)
Can’t really see anything else. So you’re experiencing video AND songs “skipping”? Could you be more specific? Could it be a problem with your network?
