@hyness said:
I am having an issue with 1.0.14. My music library is disappearing after its scanned in properly during a phase where kodi says its reading media information from files. Debug logs sent in private message.
Same issue here. Please let us know what the developer has to say once he takes a look at the log.
I can’t find @croneter exact post but I believe he/she is aware if this or something similar.
Just curious what @hyness setup consists of: Mine consists of ReadyNAS 516 running the latest PMS and I have 2 NSATV running SPMC 16.1.2. Will try on a Windows box and see if the Music section exhibits the same behavior. Movies and TV Shows are fine, just Music section is having issues.
This was the quote from @croneter That I was thinking about:
OK, this one is for the more adventurous. For movies and TV series, you can now use direct paths. HOWEVER, Plex needs to be set up accordingly and your Plex libraries need to point to e.g. "\myNAS\movies". For music it actually works, too, but Kodi chooses to delete all songs instantly .
You have been warned
Changelog
version 1.0.12
Possibility to use direct paths (you need to reset!)
Changelog
version 1.0.12
Replicate Plex views in video nodes
Thanks, and yes that is what is happening unfortunately. Did @croneter mention that this would be addressed in a future release?
@MartinAyla said:
What’s the status on PKC and subtitles, with direct paths?
Should the subtitle downloader work, and what about external srt files?
Edit: To answer my own question, just did some tests and both subtitle downloading and external subtitles seem to work. Nice
I’m using the standard setup, not direct paths, with latest PKC. Will I be able to use external srt subtitles in the future? Not sure if this question has been answered.
Just installed this and Synced my TV + Movie libraries, but for some reason playing anything using the ‘Addon’ option doesn’t show anything as ‘now playing’ in Plex. Anyone else having this issue? Or is it just due to the way the plugin works?
Is there any way to access the local trailers and extras on my Plex Server via PKC in Kodi? I got a bunch of deleted scenes, making of and other stuff.
Deactivate info “Gathering information from files” for Music
Updated readme
Known issues/bugs
Constant PKC background sync polling can put strain on certain PMS
Plex Music: direct paths don’t work yet
Plex Music: Kodi still tries to gather information for every single song, due to very unfortunate coincidences in the way Kodi and Plex are working (Plex puts each song in a “dedicated folder”, e.g. ‘http://192.168.1.1:32400/library/parts/749450/’. Kodi unsuccessfully tries to scan these folders). Please share your experiences with your Plex Music setup. Maybe it ain’t that bad
Some widgets appear broken, e.g. Movies On Deck. I have no idea why
PKC syncs the Plexpass trailers to Kodi. You need a skin featuring a “trailer shortcut” to access the trailer.
Just curious… i was doing a fresh setup of Kodi and couldn’t get plexbmc to work (shame since it was perfect…) So i setup Connect… i have like 8 shared servers that i connect to but can only seem to see the single server i picked during setup… is there a way to add alll of the servers?
Updated readme
Known issues/bugs
Often, a context menu is unavailable
Again thank you for this great addon! One question from a Music perspective, can you still specify native paths and leave the Music paths blank/null or if you specify native paths you have to define for all? Just curious before I go down this road again given my Music library is very large, ~3TB
Given the issues around the Music section my thinking if you leave the paths for Music blank the addon will scan the section via the addon default?
I just didnt specify a path for music and PKC ignored my music library completely.
