I recently installed Plexpy and it’s great. Had to reboot server, but now getting an username password prompt box?
not accepting my plex.pass login or anything else. Can anyone assist please?
Are you referring to a login when you try and access via a web browser?
If so surely this will be the username/password you set in the http config options (which will most likely be different to your plex acc)
I’m sure I’ve checked that. I’ll try again and report back. Thanks
working, fanastic!
thanks for your help
@SCGOutlook said:
working, fanastic!thanks for your help
