PM4K / PlexMod for Kodi (18, 19, 20, 21, 22+)
Thank you
No worries, thank you for reporting! Are you using the lsio/plex docker Image by any chance?
Issue has been raised with PlexInc btw.
You mean for the server side?
My Plex server is running on Windows 11 unfortunately sorry.
Many thanks for your work really a great app!
How to do a rollback? I am using Proxmox LXC with ubuntu 20.04, so no docker here too, sorry.
Hey @panni
Can you take a look on this Pull-Request?
This Pull-Request fixes some German strings and add new strings where are missing.
1.32.7.7484 is definitely broken for my RPi-4 with the same info as @scharnhorst and screen shot.
Same Kodi and Mod versions too.
Rolled back to 1.32.6.7468 and all working.
Plex server running on Synology DSM 1019+
{old link https://downloads.plex.tv/plex-media-server-new/1.32.6.7468-07e0d4a7e/synology-dsm7/PlexMediaServer-1.32.6.7468-07e0d4a7e-x86_64_DSM7.spk]
Thank you, I will once I find the time. I’ve got a good list of little fixes it needs. I’m currently contemplating to make Omega the go-to supported version right now. PM4K runs well, just some bugfixes necessary.
Maybe I’ll get to it on the weekend.
Same here. 1.32.7.7484-7000.
RPi 4 Libreelec 11.0.3
Plex 0.5.2-beta1.1
If anyone has a link to 1.32.6 for x86_64_DSM7 (DS918+) do let me know. I can roll back and test it.
@panni , anything/debug you’d like me to provide that may help troubleshoot this before I roll back?
You could collect debug logs from the PMS after triggering the issue. Maybe it helps the Plex team to identify the culprit in the 404ing endpoint. Thanks!
No worries, I’ll hold off on the downgrade and commit to that tomorrow.
well a rollback is nothing other than stopping the pms service, downloading the (older) target deb file and installing it with dpkg -i and starting up pms service again. just in case anyone needs this useful piece of information on how to “rollback” pms.
@panni in case it helps,
I’m still figuring out how to share my tshooting logs with the admins but not publicly (for privacy reasons).
Well, you could DM me and I’d forward the logs to the relevant people.
Guys, if you can, please check whether this PMS release still has the issue or not.
Thank you!
Is it possible to add the watchlist section?
That is what is definitely still missing.
Is it feasible?
Hmm,
It seems I can’t roll back and test the release you want me to.
Screenshot 2023-09-20 at 9.06.52 AM
@Sam_AU
Looks like a Syno?
Normal “Syno” rollback is:
  1. Uninstall the higher numbered version (“Uninstall Only” - KEEP on DSM 7)
  2. Install the lower numbered version
(Syno is strict on version control)
Thanks @ChuckPa , that did it.
@panni , I can confirm this version fixes the issue.
PlexMediaServer-1.32.6.7515-873995547-x86_64_DSM7.spk
Can you provide PMS debug logs for this? PM4K has a wildly different MediaDecisionEngine profile that’s reported to the PMS, to support AV1 and audio passthrough properly.
Seems like something’s gone awry in the meantime regarding 3D.
The fact that you had to wait for anything to play indicates that the server started transcoding, normally.
Solid background color setting will be in the next version.
