I’m trying to install PMS 1.0.2.2413 on an Asustor AS6204T NAS via the manual install method, which uses an .APK file.
The problem is the the NAS will not load the APK file. Other APK’s load fine - I’m thinking there is a problem with this file.
Would you please try to reproduce the problem, or just compile a fresh copy of the APK and post it so I can try loading it on the NAS?
Regards.
Since users in this forum may use a large variety of operating systems, posting in the section of the forum for Plex Media Server for your operating system will allow you to find users who are familiar with that operating system and can help you with installation issues on that operating system.
See forums.plex.tv/discussion/comment/1221985/#Comment_1221985
Just my 2 cents.
PMS may be better off on your PC (or equivalent) PMS is CPU intensive and your Celeron CPU is probably minimum. I think an i3 or higher is better off at this task.
I have a Qnap NAS with an older generation Celeron (2 core). I had no problems installing PMS. it seems to run OK but I had a pause in between chapters of the movie. No transcoding either. I put the PMS on my PC with an I3 and everything is fine.
Your NAS may do better than mine, though.
Just thought it may be worth mentioning.
