PMS 1.15.6.1079 Error in the Spanish translation
Server Version#: 1.15.6.1079
I just updated my PMS in my Synology to the version 1.15.6.1079 and now there are many words aren’t translated to Spanish.
Where says “Season 1” / “Season 2” … should says “Temporada 1” / “Temporada 2” …
On deck → En progreso
Recently Added TV → Series añadidas recientemente
Recently Added Movies → Películas añadidas recientemente
And a lot of more errors:
In previous versions everything was correctly translated
Others topic with the same problem:
Well hopefully it will be solved quickly … for next updates you will have to be very careful … because it is also that if you want to install the previous version it will not leave you … I will be aware of this thread … Greetings
Solve with the last update - version 1.16.0.1226
