Server Version#: 1.24.4.5081
Player Version#: 6.2.4-25556 update 2
Model: DS418play w 6 gb RAM
server log Plex Media Server Logs_2021-10-22_12-13-58.zip (3.3 MB)
attached… The crashing pre-dates then last upgrade of DSM and PMS.
thanks, BP
thanks, BP
Oct 21, 2021 17:49:29.312 [0x7fc2005a5b38] DEBUG - * Scanning /volume1/Plex/Library
Do you have a library pointed at /volume1/Plex/Library?
If so, remove it immediately. /volume1/Plex is a reserved location when running Plex on DSM 6. Do not place any media files in that directory or any subdirectories. Do not add it, or any subdirectories, to any library.
I do not have such a library… i do have the plex volume on synology, created by PMS. no library. no media files there, only an application support subdir created by Plex
this was done a couple years back. actually have a Media volume with my libraries underneath. worked fine for 2+ years and then this problem arose…
can someone help me diagnose by looking at my logs? they are Greek to me
BP
I just checked your certificate. It was dated Sept 5th.
Anything in Sept is subject to question, imho.
I reset the certificate for you.
Please restart PMS.
Thanks. Is the cert on,y used when secure connections are on? How did you reset it?
Peter,
I went into your account at Plex.tv
I saw the date the certificate was issued by Plex.
I’ve seen problems with anything issued prior to Oct 1 (this Sept 30 bounary crossing).
To address the certificate aspect itself, I’ve reset it so you will get a fresh certificate when PMS next restarts
I have sent you a PM.
Chuck. thanks again. it ran for 5days until yesterday and then crashed again 2x yesterday. I set secure networks to disabled. Should this help until theres a long term fix? appreciate your help thus far!!
I installed the old version and its working great. this forum site is difficult to navigate. cannot find my messages or my posts easily so i am replying to an earlier post. really appreciate all your help.
Barry
Greer, SC
If you go to your Forum Profile (upper right – click the Avatar)
Set notification.
You can set it to automatically email you when someone replies to your posts / threads or even sub-forums you subscribe to.
This is how I’m notified of all Synology and Linux forum posts.
