Hi, I have a Network Tuner, it is unsupported but Plex Media Server on my PC finds it straight away and it works fine, PMS on my Shield Pro which is on the same network can’t find it, even if I add the ip manually, the circle just spins.
Is there something extra that needs enabling on shield to see the tuner, I don’t really want to run it on the PC.
Tuner is DTT-IP quad Terrestrial.
Thank you.
