PMS crashing
Hello
I’m posting this here cause I do not see how to make a request in forums
The new version of Plex media server released on July 24th 2023 is causing a lot of crashes on mac systems. Version 1.32.7349
There seems to be an issue with Plex transcoder within the package contents, as described in my Apple console. Please provide a fix! It’s been crashing 2-3 times a day ever since July 24th
Thank you and have a lovely day
What exact error message do you see in the console (or possibly your server logs)?
thanks for the reply,
here is what shows in the console (the important part i think anyways)
please see the users reporting the crash in the reddit post :
https://www.reddit.com/r/PleX/comments/15apylx/server_keeps_crashing/?utm_source=share&utm_medium=ios_app&utm_name=ioscss&utm_content=2&utm_term=1
Translated Report (Full Report Below)
Process: Plex Transcoder [22130]
Path: /Applications/Plex Media Server.app/Contents/MacOS/Plex Transcoder
Identifier: Plex Transcoder
Version: ???
Code Type: X86-64 (Native)
Parent Process: Exited process [18467]
User ID: 501
Date/Time: 2023-07-24 22:13:44.5149 -0400
OS Version: macOS 13.4.1 (22F770820d)
Report Version: 12
Bridge OS Version: 3.0 (14Y910)
Anonymous UUID: 084CA438-A29E-AEC8-F046-D784FE75472F
Time Awake Since Boot: 900000 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000028
Exception Codes: 0x0000000000000001, 0x0000000000000028
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [22130]
VM Region Info: 0x28 is not in any region. Bytes before following region: 140737487077336
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
UNUSED SPACE AT START
shared memory 7fffffec8000-7fffffec9000 [ 4K] r-x/r-x SM=SHM
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libavformat.59.dylib 0x106d18e41 0x106b2e000 + 2010689
