M2 Mini Transcoder Crash
Server Version#: 1.32.2.7100 and 1.32.3.7089
For the past 5 or so days I have been having the most random crashes. There doesn’t seem to be any reason to it. On my M2 Mac mini, running macOS 13.4, the Plex Transcoder service will randomly exit and crash the application. I have the Mac logs for it and the Mac is saying that its the transcoder. I’m wondering if I could get some help on this. Plex has been running fine on it since the day the M2 came out. Its just started happening in the last few days. I have ran 2 database repairs and both of them showed nothing wrong. I ran the SQLite method and the Github Script and both provided the same OK note on the database. Is anyone else having this issue? I can provide the Mac crash logs if needed or anything else if you can specify which logs will be needed. Thanks!
Edit: If anyone wants to take a look. I added a zip of my macOS transcoder crash logs. Hoping someone can provide some input. Thanks!
Plex Transcode Crash macos: REMOVED
Edit 2: In case anyone comes across this, someone in another thread was having a somewhat same issue. Basically, I had a few episodes from “The Boys” that were crashing the transcoder. I was able to reproduce this down to the very second. If anyone runs into something that sounds like this, see what file is playing when the server crashes.
This sounds similar to my issue:
It seems to happen at the end of episodes. where the server just crashes.
I feel it only started happening when I upgraded my Mac Mini M1 to MacOS 13.4.
How did you resolve your issue?
I’ve been trying to work out why its been transcoding for me. when I’m direct playing. Seems .srt subtitles on an LG tv are direct stream. Which is kicking of the transcoder.
I’ve downgraded all the way back to Version 1.31.1.6733 and so far with a few episodes playing can’t replicate the crash. Hoping sticking to the old version is the fix for me.
For me it was the encoding of a few episodes in the series. I had to re-encode them and my issues went away. I guess the transcoder just had an issue with them and would crash the whole server.
Anyone still getting these crashes, please run with debug logging enabled and when the server crashes, restart the server and download the server logs
Also Use the Finder’s Go menu, select Go To Folder… then enter the following in the dialog box that pops up:
~/Library/Logs/DiagnosticReports/
then copy out and zip any file mentioning plex
Attach the server logs zip and the diagnostic reports files zip
thanks
I have the same crash reproducible, so I will get the diagnostic reports and debug server logs
But I will post it on the below thread as I’m on an M1 with Xbox client, and it happened on 1.32.4.7195 and still now on 1.32.5.7318
Thank you - @lantrix
I have a Plex Media Server development build to offer to Mac OS users that have been getting server crashes when the transcoder crashes out - this will not stop the transcoder crash but address the server crash issue
I will make this build available to Mac users who have passed me evidence of the server crashes - anyone else affected and willing to try, do let me know
Hello @sa2000 , I have been having this same issue for approximately the last 4 PMS versions. Please find the diagnostics and server logs attached. I would love the development build that will address the server crash issue!
Plex Media Server Logs_2023-08-16_17-55-01.zip (3.5 MB)
Plex Diagnostics.zip (41.7 KB)
You had a transcoder crash at 2023-Aug-16 16:50 which brought the server down
We have a fix coming out for the server crashing when the transcoder crashes and we now also have a fix for the transcoder crashes when subtitles are in use and they finish before the end of the movie
I will give you access to a development build that fixes both of these issues
Also have an M2 Mac running PMS. Getting near daily crashes which is abnormal. Where would I look to see if I’m experiencing a transcoder crash like the OP? Thanks!
Please go to this folder with Finder
and see if there a Plex Transcoder file created at the time of the Plex Media Server crash
Thank you. Provided Transcoder logs in the other Mac Thread
Thanks - I have added you to the PM thread - you should now have access to the development build 1.32.7.7407 which has a fix for the Plex Media Server crashing when the transcoder crashes and also a fix for the transcoder crash when coming to an end for subtitles before end of the movie.
The fixes have now been released in the 1.32.6 beta - version 1.32.6.7468
  • (Mac) Transcoder crashes would cause PMS to exit (#14414)
  • (Transcoder) Unexpected behavior when subtitles ended before the end of video (#14426)
