Server Version#: 1.20.3.3437 (Synology DS1812+)
Player Version#: 6.6.12.6662-64d4a08ac-Plex (TCL Roku TV R613)
PMS cannot maintain high bit-rate Direct Play stream from Synology DS1812+.
Im playing high(est) bitrate 4k mkvs (1917, some MCU films, etc) and playback fails with error that network is insufficient for the quality/bitrate.
I suspected issues everywhere but PMS. So I began redundantly doing isolation testing everything else. I thought it was bad wifi to the tv, insufficient bandwidth on the 10/100 nic on the tv hardwired, the processor on the tv not being able to keep up, my wifi roiuter/AP not being able to keep up etc.
I cam to this conclusion by spinning up a second instance of PMS on my wifes computer, compying 1917 onto it, then playing it direct direct play across the same network connections to the same client. It didnt buffer drop/buffer once.
That only leaves 2 things that could be broken, my Synology itself, or PMS.
Using SMB to copy 1917 off the NAS to my wifes computer it saturated the NAS’s gigabit nic with stable and sustained transfer speeds ~108-130MBps which is 10x the needed speed to Direct Play the movie which seems to rule out network or drive access hardware issues.
1917 is listed in PLEX at `85Mbps, but I know it routinely can spike to 120-150 Mbps which outstrips the capability of the TVs ethernet port, but the AC wireless on the tv was able to handle it fully when played from my wifes desktop PMS install.
I cant be sure if its a bug in PMS for synology or some rotten configuration causing the issue. I explicity disabled transcoding on each server, and select original quality force direct play on the client. While streaming from synology, not a single resource is stressed (disk io, proc, ram, nic, etc) My synology is working like a champ in all other aspects, its only these high bitrate direct streams from PMS that I am having issues. (lower- full bit rate HD blu ray mkv’s play fine)
Seeking support to determine if this is a PMS bug, an inadvertent config issue, a corrupted config issue, something new, something else. But I do know what ever the problem it is specifically coming from the synology pms client on my nas, as I have tested the raminder of the ecosystem to work flawlessly.
Any help appreciated.
-Log Attached
Plex Media Server Logs_2020-10-21_DEBUG.zip (5.3 MB) Plex Media Server Logs_2020-10-20_Verbose.zip (5.0 MB)
