PMS does not see NAS after changing password
DS2719+
DSM 7.1.1-42962 Update 4
PMS 1.31.1.6716-7000
Logs.zip (5.3 MB)
while I was in my network I guess was in this date 2023/02/07 I changed the password in my android phone plex app because ome of the users was not having access to files in PMS after that PMS does not see my NAS I updated everything, which I dont think would help but I was following some instructions how to log out and log in in all the PMS applications
Couple of issues:
Network config
Your machine has all 4 adapters plugged in and on the same subnet running as peers.
This isn’t how to do it.
Make them a bond adapter (which gives the capacity) but presents only 1 IP address and makes everything happy (including authentication)
Feb 21, 2023 11:39:54.999 [0x7f658ebaaaa0] DEBUG - Network interfaces:
Feb 21, 2023 11:39:54.999 [0x7f658ebaaaa0] DEBUG -  * 1 lo (127.0.0.1) (00-00-00-00-00-00) (loopback: 1)
Feb 21, 2023 11:39:54.999 [0x7f658ebaaaa0] DEBUG -  * 3 eth3 (192.168.50.204) (00-11-32-97-1C-F4) (loopback: 0)
Feb 21, 2023 11:39:54.999 [0x7f658ebaaaa0] DEBUG -  * 4 eth2 (192.168.50.203) (00-11-32-97-1C-F3) (loopback: 0)
Feb 21, 2023 11:39:54.999 [0x7f658ebaaaa0] DEBUG -  * 5 eth1 (192.168.50.200) (00-11-32-97-1C-F2) (loopback: 0)
Feb 21, 2023 11:39:54.999 [0x7f658ebaaaa0] DEBUG -  * 6 eth0 (192.168.50.222) (00-11-32-97-1C-F1) (loopback: 0)
Feb 21, 2023 11:39:54.999 [0x7f658ebaaaa0] DEBUG -  * 1 lo (::1) (00-00-00-00-00-00) (loopback: 1)
In the Syno:
Control Panel - Network - Network Interface – Create bond and select all 4 adapters.
When its completed, the NAS will still be at your primary of 192.168.50.222.
Notify table overflow
You also have so much music indexed that you’ve overflowed the notify table (which monitors for media additions AND is needed for Dolby audio transcoding.
Feb 21, 2023 11:40:45.468 [0x7f6587cf2b38] ERROR - [Notify] Failed to add watch for "/volume1/Music/Music/Label/Drumcode/(DC139) Victor Calderone - Burden (2015)" (28: No space left on device)
Feb 21, 2023 11:40:45.478 [0x7f6587cf2b38] ERROR - [Notify] Failed to add watch for "/volume1/Music/Music/Label/Drumcode/(DC140) Alan Fitzpatrick - For An Endless Night (Jel Ford Remix) (2015)" (28: No space left on device)
Feb 21, 2023 11:40:45.479 [0x7f6587cf2b38] ERROR - [Notify] Failed to add watch for "/volume1/Music/Music/Label/Drumcode/(DC141) Adam Beyer - Stone Flower (2015)" (28: No space left on device)
Feb 21, 2023 11:40:45.479 [0x7f6587cf2b38] ERROR - [Notify] Failed to add watch for "/volume1/Music/Music/Label/Drumcode/(DC142) Various - A-Sides Vol.3 (2015)" (28: No space left on device)
Feb 21, 2023 11:40:45.504 [0x7f6587cf2b38] ERROR - [Notify] Failed to add watch for "/volume1/Music/Music/Label/Drumcode/(DC143) Bart Skils - Lost Boys (2015)" (28: No space left on device)
Here’s the procedure to use for customizing the Syno per your needs.
It’s written such that, as your media grows, you update the needed size (within reasonable limits of memory installed) and then restart the Syno to make effective
Authentication
When you changed the passwords, your PMS also needed updating (the old Plex Token was invalidated.
You have two choices but the easiest for most seems to be
  1. Uninstall the package (use the KEEP – first radio button – option to save everything)
  2. Reinstall the exact same package again – EXCEPT
  3. Click the “New or Lost servers” – Plex Claim Token install assist
  4. Click the “Get Plex Claim Token”
    – browser opens
    – New token presented
    – COPY that token to the browser
    – Return to the installer page
    – PASTE the claim-xxxxxx token into the box.
    – NEXT NEXT DONE and let it install / reclaim to your account
  5. It’ll take a few extra seconds to do this but when done, it’ll confirm it’s claimed by YourPlexUsername again
Now you should have everything
HOW TO’s
  1. Increase number of folders PMS can monitor
  1. Reclaim / fix credentials after password change
thank you
looks like a lot of work, but I will try to do it as you explain it
and spend some time reading more FAQ
