I’m not sure what to do here, I’ve been running PMS on a raspberry Pi 4 for about two years now, never had any issues. Now all of a sudden, it’s not running, the Plex apps I use won’t connect, and the localhost refuses to connect when I try to open Plex Web on the Pi the server is running on. If I need to include some logging info or anything, let me know what is needed and I will provide it. I’ve never had any issues, so I’m new at having problems. lol
I ran sudo systemctl status plexmediaserver
and got this output.
● plexmediaserver.service - Plex Media Server
Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Wed 2021-03-17 20:41:09 EDT; 44s ago
Process: 968 ExecStartPre=/bin/sh -c /usr/bin/test -d “{PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir -p "{PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}” (code=exited, status=0/SUCCESS)
Process: 970 ExecStart=/bin/sh -c export PLEX_MEDIA_SERVER_INFO_VENDOR="(grep ^NAME= /etc/os-release | awk -F= "{print \$2}" | tr -d \" )"; export PLEX_MEDIA_SERVER_INFO_DEVICE="PC"; export PLEX_MEDIA_SERVER_INFO_MODEL="(uname -m)"; export PLEX_MEDIA_SERVER_INFO_PLATFORM_VERSION="$(grep ^VERSION
Main PID: 970 (code=exited, status=127)
Mar 17 20:41:09 raspberrypi systemd[1]: plexmediaserver.service: Service RestartSec=5s expired, scheduling restart.
Mar 17 20:41:09 raspberrypi systemd[1]: plexmediaserver.service: Scheduled restart job, restart counter is at 3.
Mar 17 20:41:09 raspberrypi systemd[1]: Stopped Plex Media Server.
Mar 17 20:41:09 raspberrypi systemd[1]: plexmediaserver.service: Start request repeated too quickly.
Mar 17 20:41:09 raspberrypi systemd[1]: plexmediaserver.service: Failed with result ‘exit-code’.
Mar 17 20:41:09 raspberrypi systemd[1]: Failed to start Plex Media Server.
lines 1-13/13 (END)
If you run “journalctl | grep plexmediaserver.service” it should give you more details of the failure, feel free to post the output here
The output of that gave me
Mar 18 01:38:11 raspberrypi systemd[1]: plexmediaserver.service: Main process exited, code=exited, status=127/n/a
Mar 18 01:38:11 raspberrypi systemd[1]: plexmediaserver.service: Failed with result ‘exit-code’.
Mar 18 01:38:16 raspberrypi systemd[1]: plexmediaserver.service: Service RestartSec=5s expired, scheduling restart.
Mar 18 01:38:16 raspberrypi systemd[1]: plexmediaserver.service: Scheduled restart job, restart counter is at 1.
Mar 18 01:38:16 raspberrypi systemd[1]: plexmediaserver.service: Main process exited, code=exited, status=127/n/a
Mar 18 01:38:16 raspberrypi systemd[1]: plexmediaserver.service: Failed with result ‘exit-code’.
Mar 18 01:38:21 raspberrypi systemd[1]: plexmediaserver.service: Service RestartSec=5s expired, scheduling restart.
Mar 18 01:38:21 raspberrypi systemd[1]: plexmediaserver.service: Scheduled restart job, restart counter is at 2.
Mar 18 01:38:21 raspberrypi systemd[1]: plexmediaserver.service: Main process exited, code=exited, status=127/n/a
Mar 18 01:38:21 raspberrypi systemd[1]: plexmediaserver.service: Failed with result ‘exit-code’.
Mar 18 01:38:26 raspberrypi systemd[1]: plexmediaserver.service: Service RestartSec=5s expired, scheduling restart.
Mar 18 01:38:26 raspberrypi systemd[1]: plexmediaserver.service: Scheduled restart job, restart counter is at 3.
Mar 18 01:38:26 raspberrypi systemd[1]: plexmediaserver.service: Start request repeated too quickly.
Mar 18 01:38:26 raspberrypi systemd[1]: plexmediaserver.service: Failed with result ‘exit-code’.
I figured out the issue. There’s a problem with the latest PMS version, I posted on Reddit, and someone told me to downgrade back to the previous version until it’s resolved, and that fixed the issue
