Server Version#: latest public
Player Version#: latest public
Hi support,
Myself and my friends have been having a hard time using the android app, I run a PMS on my windows PC, and there are some movie titles which my android app won’t access.
I have rounded the problem down to a metadata specific problem and android parsing the metadata provided by plex’s default agent.
If I change the topmost agent to local asset metadata then add an .nfo within the movie, it loads in android without a problem, but if I revert back to plex’s Plex pass movie scanner agent, the match doesn’t load within the android app.
I have tried fixing the match, I have tried analysing the movie, I have tried cleaning bundles, optimising databases, restarting the server, clearing the android apps cache, and data, and uninstalling the app and reinstalling it, and refreshing the metadata at movie and library levels.
The only fix I have found so far is to add a .nfo to the movie folder and change library agent priorities, which is less than ideal to perform in say a remote access situation for specific titles giving us these problems.
The latest movie title I will refer to at present is The Old Guard 2. (2025), and according to Plex logs the metadata is being fetched within milliseconds, and being sent to the android client successfully, but the android client will hang for around 45 seconds to produce an black oops error screen with options to go back or retry.
Would it be possible to look at this translation of metadata across the platforms, to see if this error can be resolved.
When using a web browser this metadata shows without a problem.
I am willing to further assist with resolving this issue but I only have access to, Plex android mobile, Plex media server windows on todays latest update. Plex frome Samsung TV app store, Plex on Nvidia shield, and Plex htpc from windows app store.
I can also confirm that this movies metadata parses correctly albeit slower on the Samsung Plex app, I must go to sleep for my work commitments but I can help investigate further should my assistance be needed.
Many thanks
