PMS Log Cleanup
The PMS Log is filled with the entry below. Any ideas on where i can begin to address this?
Server Version#: 1.25.3.5409
Player Version#
Jan 31, 2022 02:10:15.356 [0x7fef247bab38] INFO - Plex Media Server v1.25.3.5409-f11334058 - Ubuntu PC x86_64 - build: linux-x86_64 debian - GMT -06:00
Jan 31, 2022 02:10:15.356 [0x7fef247bab38] INFO - Linux version: 18.04.6 LTS (Bionic Beaver), language: en-US
Jan 31, 2022 02:10:15.356 [0x7fef247bab38] INFO - Processor Intel(R) Core™2 Duo CPU E8400 @ 3.00GHz
Jan 31, 2022 02:10:15.356 [0x7fef247bab38] INFO - Compiler is - Clang 11.0.1 (https://plex.tv b587490162c22e078c314e3f7dc560c691d126aa)
Jan 31, 2022 02:10:15.356 [0x7fef247bab38] INFO - /usr/lib/plexmediaserver/Plex Media Server
Jan 31, 2022 02:10:15.309 [0x7fef1d7e7b38] ERROR - [Transcoder] [aac @ 0x7ffb04b10940] channel element 2.11 is not allocated
Jan 31, 2022 02:10:15.309 [0x7fef1e463b38] ERROR - [Transcoder] Error while decoding stream #0:1: Invalid data found when processing input
Need DEBUG logs zip AND the XML of the media item which causes this.
Possible causes:
  1. Damaged Media
  2. Damaged codec.
If this is DVR then unfortunately cannot help as I do not have LiveTV/DVR capability here.
