PMS not working on qnap nas. Cant open 192.168.0.19:32400
Server Version#:4.4.1.1146
Player Version#:1.18.3
Hi all
This is my first NAS so im a bit of a newbie. Got my qnap TS-453Be as a christmas gift for myself, I installed it and updated firmware and got the newest version of PMS and the first time i tried it, it worked with no problems. I was able to clame server and play media on my other devices.
But after that first time it have never worked, I have no ide what I can have done. The error i get is that i cant connect to 192.168.0.19:32400
I use a static Ip
Ive tried downgrade both firmware and PMS, dident work
Ive factory reset NAS and upgrade to newset versions, dident work.
Other programs like Download station is working fine.
Any help would be much appriciated
Since you say you reset your NAS, then make sure you use http and not https to perform the initial claiming.
After that is done, you can use https
Tried both http:// and https://, even tried with different browsers.
If so, it sounds like either PMS is not running, or not bound to the expected IP address.
Try and read this thread:
And please let me know the outcome
Plex Media Server.log (393.8 KB)
Nothing wrong according to the log…
Please try and follow this post:
QNAP NAS Plex not listening on 32400 after re-installation and the one next to it
[~] # ps aux|grep Plex
8437 admin 56060 S ./Plex Media Server
8470 admin 48900 S N Plex Plug-in [com.plexapp.system] /share/CACHEDEV1_DAT A/.qpkg/PlexMediaServer/Resources/Plug-ins-349e9837e/Framework.bundle/Contents/R esources/Versions/2/Python/bootstrap.py --server-version 1.18.3.2156-349e9837e / share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-349e9837e/System.b undle
8619 admin 14496 S /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Plex Tuner Service /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Tuner/Private /sh are/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Tuner/Shared 1.18.3.2156-349e 9837e 32600 /waitmutex
8661 admin 33368 S Plex Plug-in [tv.plex.agents.music] /share/CACHEDEV1_D ATA/.qpkg/PlexMediaServer/Resources/Plug-ins-349e9837e/Framework.bundle/Contents /Resources/Versions/2/Python/bootstrap.py --server-version 1.18.3.2156-349e9837e /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-349e9837e/PlexMu sic.bundle
8665 admin 39752 S Plex Plug-in [com.plexapp.agents.themoviedb] /share/CA CHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-349e9837e/Framework.bundle /Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.18.3.2156- 349e9837e /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-349e983 7e/TheMovieDB.bundle
8913 admin 31936 S Plex Plug-in [com.plexapp.agents.plexthememusic] /shar e/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-349e9837e/Framework.bu ndle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.18.3.2 156-349e9837e /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-349 e9837e/PlexThemeMusic.bundle
9460 admin 31972 S Plex Plug-in [org.musicbrainz.agents.music] /share/CAC HEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-349e9837e/Framework.bundle/ Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.18.3.2156-3 49e9837e /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-349e9837 e/Musicbrainz.bundle
9793 admin 41900 S Plex Plug-in [com.plexapp.agents.thetvdb] /share/CACHE DEV1_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-349e9837e/Framework.bundle/Co ntents/Resources/Versions/2/Python/bootstrap.py --server-version 1.18.3.2156-349 e9837e /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-349e9837e/ TheTVDB.bundle
10620 admin 1024 S grep Plex
[~] # netstat -na | grep “32400”
tcp 0 0 :::32400 :::* LISTEN
Hmmm…
It’s on IP V6 it seems…
Follow this post:
Turned the IPv6 off on my nas. Now terminal looks different i think :face_with_monocle:
22816 admin 1028 S grep Plex
27717 admin 50312 S ./Plex Media Server
27729 admin 48688 S N Plex Plug-in [com.plexapp.system] /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-349e9837e/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.18.3.2156-349e9837e /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-349e9837e/System.bundle
28072 admin 14660 S /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Plex Tuner Service /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Tuner/Private /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Tuner/Shared 1.18.3.2156-349e9837e 32600 /waitmutex
28099 admin 43420 S Plex Plug-in [com.plexapp.agents.imdb] /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-349e9837e/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.18.3.2156-349e9837e /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-349e9837e/PlexMovie.bundle
tcp 0 0 ::ffff:192.168.0.19:32400 ::ffff:83.249.254.191:56263 SYN_RECV
tcp 0 0 ::ffff:192.168.0.19:32400 ::ffff:83.249.254.191:56261 SYN_RECV
tcp 0 0 ::ffff:192.168.0.19:32400 ::ffff:83.249.254.191:56262 SYN_RECV
How to change EnableIPv6=“0” i have no ide how to do. :sleepy:
Download the file, open with like Notepad ++, if on windows, and add the setting. Then copy back up, and restart PMS from the AppCenter
And REMEMBER: BACKUP !
When i open it, it looks like this:
<?xml version="1.0" encoding="utf-8"?>
And i changed it to this:
<?xml version="1.0" EnableIPv6="0" encoding="utf-8"?>
Still not working after restarting PMS. Now is like it wont even start properly
12623 admin 30672 S ./Plex Media Server
15328 admin 1092 S grep Plex
make that:
<Preferences EnableIPv6="0" />
And very odd indeed, that your prefs file looks like that
And remember to restart afterwards
Cant post code i guess, i make a print screen
Now its same as before, Plex wont start.
BTW thank you so much for taking your time to help me.
LOL, and okay…
Move EnapleIPv6="0" one line down, and then delete the remaining of line 2
Now we are getting somewhere…
Your PMS is nor listning on pure IPv4, and seems like it’s recieving a call from an IP adress, but that address is NOT on the same IP Net (192.168.0.x)
During initial setup, the workstation doing this MUST be on the same IP Net, so what’s the IP of your workstation?
Sadly not, but do see now you are on Windows…
Open a terminal (Press Windows button, and type CMD)
Then in that, type ipconfig /all and paste the output
Also needs to know, if you installed some kinda firewall on your QNAP?
Windows IP Configuration
Host Name . . . . . . . . . . . . : LAPTOP-16J35H1A
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : home
Ethernet adapter Ethernet:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . : home
Description . . . . . . . . . . . : Intel® Ethernet Connection I219-V
Physical Address. . . . . . . . . : EC-21-E5-45-6A-1F
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Anslutning till lokalt nätverk* 2:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : 44-85-00-E7-82-4B
Wireless LAN adapter Anslutning till lokalt nätverk* 4:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
Physical Address. . . . . . . . . : 46-85-00-E7-82-4A
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : Intel® Dual Band Wireless-AC 8260
Physical Address. . . . . . . . . : 44-85-00-E7-82-4A
IPv6 Address. . . . . . . . . . . : fdaa:bbcc:ddee:0:397e:277d:e6b4:5558(Preferred)
Lease Obtained. . . . . . . . . . : den 1 januari 2020 11:10:36
Lease Expires . . . . . . . . . . : den 1 januari 2020 21:19:58
Link-local IPv6 Address . . . . . : fe80::35c5:77f9:a06b:cddb%7(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.10(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Expires . . . . . . . . . . : den 1 januari 2020 22:16:50
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DHCPv6 IAID . . . . . . . . . . . : 54822144
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-20-29-35-B5-EC-21-E5-45-6A-1F
DNS Servers . . . . . . . . . . . : fdaa:bbcc:ddee::1
83.255.255.1
83.255.255.2
NetBIOS over Tcpip. . . . . . . . : Enabled
Connection-specific DNS Suffix Search List :
home
Ethernet adapter Bluetooth-nätverksanslutning:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : 44-85-00-E7-82-4E
C:\WINDOWS\system32>
Have not installed any firewall myself
Hmmm…And browsing to: http://192.168.0.19:32400/web doesn’t work?
And please press the link above
And as a side note: En hälsning från Danmark, gott nytt år :wink:
