Was watching content on Friday with no issues. Yesterday I copied some new files over to it and when I tried to go into the UI it was completely down.
Went on to the Shield itself and verified that there were no updates to the PMS (said there wasn’t) and verified it still had access to the file system (it does).
Went thru the logs and the only log since Friday is a Startup Crash.log file that simply says:
“Failed to initialized logging: Empty or non-existent file”.
My google-fu has failed me and the Plex sub-reddit is still dark. Anyone have any ideas?
ETA: Fwiw, this location only had a “cache” folder in it: Android/data/com.plexapp.mediaserver.smb/
I created a Plex Media Server/Plus-in Support/Databases folder within it and copied the 2 db backup files over (renamed). That still didn’t fix it and no other update to the logs. I’ve never been in this directory before so have no idea what it used to look like. Possibility that the whole folder structure got wiped and I need other/different files here?
Really don’t want to uninstall PMS and start over
