PMS on SHIELD - No network connection, Server not available
Server Version#: v.1.22.1.4228
Player Version#: 8.14.1.23548 (88dd4b13)
Hello,
since yesterday i cannot use my plex / plex media server on my NvidiaShield Pro 2019
On the startscreen i got the message: No internet connection (Youre offline…)
On a library: Add media to this library…
I can’t connect to my local IP:Port to the PMS.
Static IP on NVidia Shield Pro (unchanged since yesterday)
Internet connection on other apps works flawlessly.
What else do you need?
UPDATE:
FIXED IT, if other has problems, clean the cache from Plex App, remove Plex App, Install Plex App again from Play Store, Login, all media should be directly presented.
