PMS on Windows 10 keeps crashing after v1.18.1.1973 update
Issues here as well.
Updated to 1973. didn’t have any problems until rebooted for windows updates.
Now all video seems to buffer for 5 minutes before starting and keeps having to buffer.
Dell R710
Windows Server 2016
Going to uninstall and reinstall older version. Anything else I can do to help Plex resolve the issue?
update:
Downgraded to 1.18.1.1966 and it still takes forever to start playback.
Downgraded to 1.17.0.1841 …same.
Did I break something with windows updates? Just installed KB4519979
update 2:
LAN playback to my roku is fine now.
remote playback to web browser player is still broken. The odd thing I’ve noticed is that on my dashboard the server thinks the video is playing (shows “playing” and time is advancing), but in the browser I just get the spinning circle.
Rolled back one version and it’s working fine for me (haven’t tested everything, I mostly do direct play).
I noticed that I was able to play MP4 files, however when I attempted to play MKV files that previously worked, Plex Media server crashes immediately. Going to try and rollback version now because disabling HW acceleration didn’t help for me.
Started crashing for me on the 1973 update, still crashing with the 1.18.2.2015 update. The server will crash randomly more often than normal, and it will definitely crash the moment I try to play a video that requires transcoding.
I’ve attached a zip of my log files.
Plex Media Server Logs_2019-11-08_00-24-43.zip (2.9 MB)
Same happening for me, I disabled Hardware Acceleration and it played a movie for the first time in days.
At first, I thought it had to do with qbittorent as I upgraded around the same time. But after rolling back qbittorrent and still having the same problem, I dug some more.
Recommended in this thread, I turned off hardware acceleration which seems to have helped.
Still figuring it all out as to what is working and what isn’t…
My logs I exported just now…Plex Media Server Logs_2019-11-08_14-50-54.zip (1.4 MB)
I am having the same issue. The Server app doesnt crash exactly it just becomes unreachable. I have tried downgrading, i went to 1.18.0.1944 and that didnt fix it. Trying 1.17.0.1841. Hardware transcoding via P2000.
After rolling back, all is working well again!
Sorry to hear that. PMS version 1.18.0.1944 is working perfectly for me.
I am on Version 1.18.2.2015 and mine keeps crashing, I have disabled hardware transcoding and will see if that works. Its weird though I directly play most of my stuff and it is still crashing. I have never had plex crash this many times on me.
I am in the same situation.
Just to update, after having Hardware Acceleration turned off for over 24hrs now, I can confirm it has made a clear difference.
No matter if qbtorrent is running or not people seem to be able to connect and stream from various clients now that HWA turned off. Locally replaying the same moves I that were failing before now all are playable.
Noticed other strange things like search not working right, but I am thinking since it clearly seems to be with PMS (or possibly NVidia) now and not my system specifically, as I first thought, I am might sit tight, since the work around is seemly working for me now, to see how soon the folks at PLEX push out an update.
Has anyone from PLEX actually acknowledged something is wrong with 1973?
I too updated to 1973 PMS a day or two ago. However, server was still operating normally. Then this afternoon a windows update ran and a restart was required. I was having PMS crash the second any device, including playback FROM the server, would start.
Found this thread - Disabled hardware acceleration on server - Presto - Playback from server, webapp, Roku and Cell Phone app now working properly.
Now - will Plex Devs please look into this? I’m hoping we see an update with the fix quickly as hardware acceleration is part of what makes this server great!
I am having the same issue. It is very consistent and repeatable with any attempt with a remote connection while hardware transcoding is enabled. I started to dig into Event Viewer logs for just a minute to see an error related NTDLL.DLL before I realized this seems to be a widespread issue. At this point I think Plex is fully aware of the issue and is hopefully working on a fix. I know crap happens sometimes, I just wish there would have been an acknowledgement by the Plex team saying it’s an issue at least. It would have been nice if that update was also pulled to investigate the issue considering this is making Plex unusable for most. Depending on how long it takes to resolve this and/or how complicated it is, I may unselect “Beta” and also put off updates for a month like I started to do with Microsoft/Windows.
Wondering if I’m having the same issue:
Faulting application name: Plex Media Server.exe, version: 1.18.2.2015, time stamp: 0x5dc4225b
Faulting module name: ntdll.dll, version: 10.0.17763.802, time stamp: 0x6071cf9d
Exception code: 0xc0000374
Fault offset: 0x000e0e43
Faulting process id: 0x5b8
Faulting application start time: 0x01d5984242567bcc
Faulting application path: C:\Program Files (x86)\Plex\Plex Media Server\Plex Media Server.exe
Faulting module path: C:\Windows\SYSTEM32\ntdll.dll
Report Id: 3c3e658d-c28d-4d1c-aa10-72d5cabcfd58
Faulting package full name:
Faulting package-relative application ID:
I installed a second server on Ubuntu (on the same network) using the same media files just as a backup. After reading this thread I’ve disabled hardware acceleration as well. Is this hardware acceleration issue only affecting Windows 10? Or I should disable it on Ubuntu as well with this version of PMS?
I have been having the same issues and am starting to consider going with a different platform. Does anyone know if these issues have been with like Apple or Linux? I have had to roll my server back to v1.18.0.1944 as it seems to have been the most reliable recently.
Same problem here
Disabled Hardware transcoding seems to fix it (without much testing for now)
Same issue here. I’ll test disabling hardware acceleration but the devs must find a solution ASAP
please follow the instructions here from Simon to get him the data he needs
So first off same issue…
question for everyone I moved to the plex windows app and that reduced 80% of my issue now only live tv crashes my server. chrome - edge crash the server whether its remote play or local to the server.
now here is the real kicker. if I use the android app phone/ nvidia shield. I have 0 issues with HW transcoding. I’ve had these issue for the last month or so but everything tests fine.
based on HW transcoding I’m wondering if there is an issue with the codecs?
