PMS Stopped retrieving Subtitles, again
Server Version#: 3.73.2
Player Version#: ? chrome ?
Once again, Plex has STOPPED retrieving subtitles. I KNOW my login at opensubtitles.org works and that the titles exist.
Any idea?
I installed subzero.
a ton of settings, but it still does Nothing.
fyi, in agents i deselected opensub and enabled subzero as it has a section for my opensub user/pw ----
This is Not a question about subzero, but PMS and it NOT downloading/retrieving/showing SubTitles.
Thanks, in advance,
Landis.
Opensubtitles has daily download limits. Did you possibly reach that?
Yes.
you know, i thought about that and that is why i knew i could login to their site and search for the titles. One is apparently not the same as the other, eh.
I trashed my db renaming files too quickly and too many, so Plex was adding All my movies at once… +/- 1,000 plus tv series. : (
Would you happen to know why SubZero with all it’s sources, also fails to retrieve subtitles?
Thank You for responding.
Landis.
It seems you were correct.
opensubs agent is working (after midnight, so they must use calender day not 24hr since last), but subzero still does not… It sounded too good to, work for me.
Landis.
I do not have any ideas why SubZero would not work for you. I would suggest you contact the developer of that plugin to ask. [REL] Sub-Zero 2.5.7.2663 - Subtitles done right
