I need some help! Yesterday nothing could connect to the Plex Media Server on my 2017 Nvidea Shield Pro. I used the remote to restart the shield but still the server was unavailable. So I pulled the power for 20 seconds and let it restart - Plex worked. 3 hours later the music stopped and PMS is unavailable. No time to mess with it so left it alone.
This morning tried a hard restart again. Plex kind of loaded on the shield but just a whirring circle or animated line. nothing would open.
Thinking I need to re install I went into the android setting on the shield and under apps was ‘uninstall updates’ for the server - so I did. Turns out that was a back to factory reset for the server to supplied version.
Open the app and try to set up the server… it goes through a few steps whirrs for 20 seconds on starting for the first time… then says something went wrong do you want to try again which just takes you through the same loop.
So I’d like to know what went wrong initially and now and how to fix it please.
media on the shield pro still plays fine with kodi and I can browse to the internal storage on the shield via my wired network.
