PMS unable to regenerate plex.direct SSL certificate
Server Version#: Docker: plexinc/pms-docker:1.22.3.4392-d7c624def
I accidentally deleted the cache directory for my plex server and now it can’t seem to get a new certificate. It has been failing to regenerate for over 24 hours now. Is there something else I need to do? I keep getting the error: CERT: Error acquiring new certificate: Failed to upload CSR: 429, <?xml version="1.0" encoding="UTF-8"?>
Apr 29, 2021 02:00:29.747 [0x7f6cbaffd700] ERROR - Exception inside transaction (inside=1) (…/Plugins/PluginDatabaseState.cpp:203): Cannot convert data to std::tm.
Apr 29, 2021 02:00:29.747 [0x7f6cbaffd700] ERROR - SyncWithIdentifiers threw an exception: Cannot convert data to std::tm.
Apr 29, 2021 02:00:29.747 [0x7f6cbaffd700] INFO - Refreshing paths watched by LibraryUpdateManager
Apr 29, 2021 02:00:31.121 [0x7f6cb8ff9700] INFO - Sync: downloaded 0 sync list(s) with 0 sync items(s): 0 new, 0 updated, 0 deleted
Apr 29, 2021 02:00:31.121 [0x7f6c4affd700] WARN - Sync: local sync directory “/config/Library/Application Support/Plex Media Server/Cache/Transcode/Sync+” does not exist
Apr 29, 2021 02:00:31.772 [0x7f6cb8ff9700] ERROR - CERT: Error acquiring new certificate: Failed to upload CSR: 429, <?xml version="1.0" encoding="UTF-8"?>
Apr 29, 2021 02:00:31.976 [0x7f6cd5d49700] WARN - MyPlex: attempted a reachability check but we’re not yet mapped.
Apr 29, 2021 02:00:51.870 [0x7f6cc57fa700] WARN - NAT: PMP, timed out waiting for response.
Apr 29, 2021 02:00:51.871 [0x7f6cc57fa700] ERROR - Error issuing curl_easy_perform(handle): 7
Apr 29, 2021 02:00:51.872 [0x7f6cc57fa700] WARN - HTTP error requesting GET https://PLEX_GENERATED_URL.plex.direct:32400/identity (7, Couldn’t connect to server) (Failed to connect to PLEX_GENERATED_URL.plex.direct port 32400: Connection refused)
I managed to get it to load finally after leaving the server entirely offline for around 16 hours without it trying to request a cert. Is there any way we can bypass this lockout if something goes wrong?
