Server Version#: 1.25.5.5492 and MANY others
Player Version#: All
Greetings;
For a long time, I’ve been a user who just takes the new plex server updates as they come. Worked well for a few years, and then - that strategy backfired badly.
At some point - adding new videos to any library that was configured as “Other Videos” no longer gets Posters created. Nothing I have tried makes any difference at all. The online help for this is… not helpful at all.
In the past, posters were always created. Now, no power in the universe seems to be able to restore that ability. I have spent a ridiculous amount of time, trying every single thing that even comes close to being applicable from the ‘support documents’ and the forums. Nothing made any difference at all. By now, I have performed every single procedure discussed in the support pages - for every single problem, just in case. NOTHING has any impact.
Finally, I found an OLD Plex server install file. I literally wiped out my entire server install, found, and removed the database in its entirety. There’s a command line tool called ‘byenow’ that reduced the amount of time this would take from about 18 hours using the Windows GUI, to about 6 hours using the command line prompt and the byenow program. (Yes I have a really big library).
After reinstalling the older version of Plex Server, this critical function of creating posters for ‘Other Videos’ was restored, and I could have a normal user experience again. I left it that way for some time. Then, I got stupid.
I said to myself - Self, the plex people will have realized this was AFU by now and fixed it. I wanted some of the new plex server fixes - and bet that Plex would have fixed the poster creation problem for ‘Other Video’ type libraries. You already know what I’m going to say next - I was WRONG. And now, I am back to having only one way forward, and that is to go backward and install an obsolete version of the plex server to get this poster creation function back working correctly.
Also, in the past, if the media hadn’t yet been analyzed, the posters would be created pretty much as soon as I began watching the video. That also doesn’t work at all in recent server versions.
I have at least just located older plex server installers, so if that’s the ONLY way to fix this, I guess I could go through that multi-hour process again. Not that I like that solution. I want this thing to work CORRECTLY. The way it used to. I don’t want to have to create posters in paint, figure out a place to keep them, and then designate them manually. I have way too many files for that nonsense.
This all seemed to happen about the time Plex Server agents for ‘Other Video’ files were “improved”.
Can anyone provide any information as to how I can get this poster creation issue behind me without having to lock down my Plex server version from sometime around February of this year? (Assuming I can somehow find an installer that old).
I’m a plex pass holder, blah blah blah, and I’m serious about wanting this back and working. It’s a genuine letdown, and the people I share with get confused when the Posters are blank/show the video title.
In brief:
Can anyone help me make Posters work again for “Other Videos”
Any help will be appreciated…
Annoyed and Frustrated, but still smiling.
