Server Version#: not sure
Player Version#: not sure
I checked on my server that I am running on Windows 11 this morning and the PMS will not boot up. It says:
“The code execution cannot proceed because libcurl.dll was not found. Reinstalling the program may fix this problem.” “The code execution cannot proceed because opencv_core455.dll was not found. Reinstalling the program may fix this problem.” “The code execution cannot proceed because opencv_imgcodecs455.dll was not found. Reinstalling the program may fix this problem.” The code execution cannot proceed because opencv_ingproc455.dll was not found. Reinstalling the program may fix this problem."
When I tell you I am not tech savvy, I mean it… Getting this thing up and running was a case of a blind squirrel finding a nut and I have only done system updates to PMS and Windows since then.
Can anyone tell me if reinstalling would be safe?
