Podcast with negative count
I noticed that, for a couple of the podcasts I added manually from an RSS feed, the “unwatched” count goes negative.
After I listen to a newly published episode the count decrements further.
I can “fix it” by marking the whole podcast as unwatched and then watched but that’s quite annoying.
Anyone else is experiencing this? Is there a way to fix it in a less annoying way?
Yup, and it’s been mentioned in passing in other threads as well. They say they’re aware and working on it.
Same issue, I switched over to plex completely for podcasts but almost wished I hadn’t. Counts go negative, shows with unwatched episodes show nothing for unplayed, etc
A podcast client that can’t even track which podcasts have been played or not…awesome.
And they even said they took it out of beta without this fixed?
Persisting here as well. Is there a ticket that can be subscribed to track progress?
Yeah, I have a show that never shows up in the on deck section because of this. Super annoying.
I have the same issue.
