Responses in BOLD . . .
What version of Plex Media Server are you running
VERSION 1.20.2.3402
4.34.4 (this is what it says for PLEX WEB)
. . . and on what platform (Win10, Linux, etc)?
WIN10
Do you have a VPN installed on your server/network? If so, disable it.
YES, I HAVE NordVPN INSTALLED ON TWO PCs IN MY SYSTEM. ONE OF THESE TWO PCs IS MY MEDIA SERVER. IT IS NOT TURNED ON. BOTH PCs ARE CONNECTED DIRECTLY BY CAT7 TO THE AT&T ROUTER.
QUESTION . . . CAN I HAVE THE VPN TURNED OFF ON THE MEDIA SERVER PC AND TURNED ON AT THE SAME TIME ON THE OTHER PC?
Configure your Plex Server for debug, not verbose, logging. This is in Server settings (not Plex Web settings) -> General. Click Show Advanced. Select the box for Enable Plex Media Server debug logging and save changes. See Reporting Issues with Plex Media Server for details.
BOTH “ENABLE PLEX MEDIA SERVER DEBUG LOGGING” AND “ENABLE PLEX MEDIA SERVER VERBOSE LOGGING” WERE SELECTED. I DESELECTED VERBOSE LOGGING, THEN SAVED CHANGES.
Review the Troubleshooting Remote Access support doc.
Are you using Automatic (uPNP) or Manual Port Forwarding?
I GENERALLY USE MANUAL., AND SET THE PORT AS 32400
I suggest using the latter, as it seems more reliable than Automatic.
I RESET IT TO MANUAL AND HIT “RETRY” BUT IT TURNED GREEN FOR ONLY A MOMENT, THEN REVERTED TO “NOT AVAILABLE OUTSIDEE YOUR NETWORK.”
If you are already using Manual, then check the port forwarding statement in your router. If AT&T had to reset the router to restore service, any existing port forwards, or other customized settings may have been deleted in the process.
I HAVE GONE INTO THE ROUTER AND THE PORT WAS NOT SET ON 32400. IT WAS ON 51600 INSTEAD. I HAVE TRIED TO RESET IT TO 32400, NOW, AS A RESULT OF THIS CHANGE, AND THEN RESETTING THE PUBLIC PORT TO 32400, MY SYSTEM REPORTS THAT “DIRECT CONNECTION IS NOT AVAILABLE.”
BUT MY AT&T MODEM/ROUTER SHOWS THAT “DIRECT ACCESS IS ENABLED”. HOWEVER, I CANNOT ACCESS THE SERVER REMOTELY, AND I TESTED IT WITH ANOTHER REMOTE USER AND THEY CANNOT CONNECT TO THE MEDIA SERVER. WHAT IS GOING ON? THIS IS SO FRUSTRATING. WHY IS PLEX SO HARD TO USE?
Make sure the rule exists, has the correct port number (ex TCP/32400), and points to the IP address of your Plex Server (ex: 192.168.x.y).
I HAVE NO IDEA WHAT YOU MEAN BY THAT STATEMENT. SORRY, I AM A NEOPHYTE
Make sure the port forwarding rule aligns with the Plex Server Settings -> Remote Access page - IP address & port number.
AGAIN, I AM NOT SURE WHAT YOU MEAN BY THAT.
Can you post a screenshot of the port forwarding rule?
WHAT IS THE PORT FORWARDING RULE?
After checking/setting the port forwarding rule and PMS configuration, try enabling remote access again.
Check remote access status. From a web browser on your server, or from a system on the same network as your server, go to canyouseeme.org . Substitute your remote access port for the default (80) and check connectivity.
I HAVE NO IDEA WHAT YOU ARE TELLING ME TO DO.
If that does not work, then pull the Plex Server log files (Settings -> Troubleshooting). Attach the entire zip file to the thread (drag it into the compose window, it will insert at the cursor location).
