I’m viewing my music library in the Windows Plex Player sorted by artist. Along the right edge of the screen is a vertical list of the letters in the alphabet, but these do not take me to the correct location in my library.
As an example, if I click on the letter “T” it only takes me to the artists that start with the letter “J”. The further down in the alphabet that I go the further it takes me in my library, but never far enough, so it it is moving down through my library, but not far enough.
If I had to take a wild guess, I have a suspicion that I may have an idea of what it is related to:
I’m running Plex on a 15" laptop with a 4k display. The default scaling was horrible because everything on the screen was crazy tiny. I recall changing the default scaling factor a long time ago. Is it possible that the calculation on how far down to scroll the display when you select a letter is not taking into account the scaling factor?
I would test this by reverting the scaling factor back to the default, but the article that described how to do this no longer seems to exist and I don’t recall offhand where to set this.
You were correct - it was an environment variable. I removed this and rebooted and found that the scaling was still good, so it seems that this may have changed somewhere along the line so that the environment variable is no longer needed.
However, this did not change the behavior of the alphabet bar along the right edge.
Also, I did verify that the shortcut for Plex has no additional parameters being specified when Plex is run.
Would be happy, if Plex could fix that bug. Can’t see any sense in a list of alphabetic letters which do not bring you to the corresponding album…
Thanks!
