Possible Bug with skin in Rasplex?
Hi All
Just got myself up and running with Rasplex and i must say its great so wanted to say thanks to the developers for the work they do in it!
I have just installed the Plex Black Edition skin and it looks really nice, i dont like the default skin at all i must say. The issue i am finding though is that on some of the views you get the option to disable background fanart when scrolling through you movie collection etc this works fine but when i try to untick the hide background fanart option it does work. The tick just stays there so there is no way of getting the fanart back on that particular view.
Not sure if its a skin issue but i guess maybe it is rather than an issue with rasplex.
Just wondered if anyone else may have used this skin and had a similar issue
Cheers
Liam
I use the skin on all my Pi’s without any problem, suggest deleting skin, rebooting, copy skin again and rebooting.
Regards
That done the trick Ned thanks for that! I have also tried another couple of skins and extracted the zip folder to the same location but they dont seem to appear in the list of skins. I noticed the Aeon had to be renamed after extraction which i did but it still wouldnt show up. Refocus did the same thing as well
Glad you’re sorted, can you please mark this topic as answered, thanks.
After copying skin folders to the RPi you need to restart to have Rasplex pick them up for selection.
Regards
Thanks again ned, it seems sometimes when you extract the skin the is an additional sub folder called the same as the top folder. Extracting that to the addons folder done the trick for Aeon, must admit though i much prefer the Black Edition skin
