I’m on a Synology running DSM 7 (Updated from DSM 6). I may have messed up the installation of PMS on DMS 7 leaving my Plex Media Server shared folder not well defined. Things ran well for a while and then PMS started consuming all memory and dying. Found my Plex database growing wildly, try to repair it but ended up having to remove the Plex database entirely and having PMS rebuild and reindex the entire DB. That took a long time but Plex has been running fine for a while now.
Issue 1: PMS shared folder not well defined
My PMS shared folder appears to be under /volume1/@apphome/PlexMediaServer/Plex Media Server. This directory has the following (from the /volume1 directory):
Wizard Jupiter:du -sh \@apphome/PlexMediaServer/Plex\ Media\ Server/*
28G @apphome/PlexMediaServer/Plex Media Server/Cache
20M @apphome/PlexMediaServer/Plex Media Server/Codecs
0 @apphome/PlexMediaServer/Plex Media Server/Crash Reports
0 @apphome/PlexMediaServer/Plex Media Server/Diagnostics
81M @apphome/PlexMediaServer/Plex Media Server/Logs
376G @apphome/PlexMediaServer/Plex Media Server/Media
17G @apphome/PlexMediaServer/Plex Media Server/Metadata
16G @apphome/PlexMediaServer/Plex Media Server/Plug-in Support
1.5M @apphome/PlexMediaServer/Plex Media Server/Plug-ins
4.0K @apphome/PlexMediaServer/Plex Media Server/Preferences.xml
Wizard Jupiter:
However in Control Panel > Shared Folder there is a shared folder named “Plex”. There is no indication of the path to that shared folder but it does say that the size of the shared folder is 1.9 gig which matches the size of the path /volume1/Plex. And all shared folders correspond to directories under /volume1. I performed a test creating a new shared folder named test and a /volume1/test folder was created. I then deleted the shared folder and /volume1/test was removed. I feel pretty confident that I can delete the Plex shared folder as there is nothing under /volume1/Plex except a Cache directory. But the question remains - where is the PlexMediaServer? Shouldn’t there be a PlexMediaServer share be listed in Control Panel > Shared Folder?
Issue 2: PMS is not updating Play History
When looking at the PMS Dashboard Play History is not updating at all. Set to Full History, All Media, All Users for the Last 30 Days shows next to no history. New movies and TV series that I’ve watched are not getting updated. I also use Tautulli and things are updating there but not in the PMS Dashboard.
Issue 3: Updating to 1.24.2.4973
So far I’m on PMS version 1.24.1.4931. All of this has been done with that version. That version was downloaded from Plex.tv. I just got a notification in the Plex Web interface of a new server version - 1.24.2.4973! @ChuckPa says that that is the version where this new PMS Shared folder is required. If that’s true then what was I running before? Maybe upgrading to 1.24.2.4973 will tie all this together and fix things but I want to ensure that issues 1 and 2 are addressed before applying that update.
Also, as I said, in the past I had to download the server software directly from Plex.tv. This new server software is now coming the regular way through a notification in the Plex Web app. Is this just because the DMS 7 version of PMS has moved to the regular method?
Note: I do not have a /volume1/PlexMediaServer. I have /volume1/Plex. Additionally I only have /volume1/Plex/Library/Application Support/Cache. There is no Plug-in Support/Databases under this tree.
I downloaded PMS 1.24.2.4973 through the standard means - Plex web page shows there’s a server update, download it, go into DMS, stop Plex server and manually install. I come up to this screen:
Yeah, I’ve noticed that too sometimes. Usually on the same file system it’s just wham and it moves. But sometimes it seems to copy+post-delete as you say. Maybe it’s btrfs?
But it looks like we’re doing well. After this finishes and things look good I will delete the Plex shared folder (and leave the PlexMediaServer shared folder).
Looks like it’s just moving like 320G. The operative command executing (pid 2966):
Wizard Jupiter:cmdline 2966
mv /volume1/@apphome/PlexMediaServer/Plex Media Server /var/packages/PlexMediaServer/shares/PlexMediaServer/AppData
Wizard Jupiter:
Does this mean that /volume1/@apphome/PlexMediaServer will no longer be used?
