Possible issue when casting to Chromecast Audio
I was using the new beta and casting to my Chromecast audio, no issues with that. When stopping the audio playback, Plex stayed open on my phone and wouldn’t dismiss from the top menu bar (Android), even when trying to use the “x” to close the app. I had to force stop the app in order for it to disappear as it normally would’ve in the stable release.
Anyone else seeing similar behavior?
Hi @johnny15 , sorry to hear you are experiencing some problems with the app.
I’ve tested the behaviour you’ve posted (playing and stopping audio playback over a CC device) and the app dismissed the audio notification as soon as the playback was stopped. Could you upload app’s logs (you can find them in Settings>Advanced>Privacy>Email device logs) ? This way we could take a further look to your issue.
Thanks in advance
Hi @jesusMC
Sorry, I missed this post. I think this is resolved. I’m currently on 5.2.0.351 and I’m not experiencing this issue any more. Thanks for the follow-up! Keep up the awesome work!
If I see any further issues, I will be sure to send device logs.
