Cannot Cast to Chromecast Audio - Has Stopped working
Server Version#: Version 4.4.1
Hey
I can’t cast audio anymore from the Android App or Chrome Browser. Everything except for Plex works through the chromecast audio
When Casting from browser, i hear it connect, then a popup says Continue Playback with a Yes or No. No matter what I press it does not connect.
When attempting to cast through the Android App I get “Error An error occurred while attempting to play this video. Please try restarting both the Plex Media Server and the app”. Irrelevant, I’m attempting cast audio.
Well I have been casting audio through plex for 2 years. What is up? I suspect an update has broken the chromecast audio.
Windows server, v1.16.5.1554
Same here. Worked flawlessly for years. Since a couple of weeks or so behaves as described above.
Please, I needs me my bedroom music. :frowning:
Please fix this. This is a huge deal for me. I will need to rearchitect how I send music to the different zones on my AV receiver if this doesn’t get solved and it will not be a cheap fix.
Same here. Has worked perfectly for years, now suddenly has stopped.
PMS 1.16.5.1554
IOS app:
I get “something went wrong” when starting to cast to CC audio or that it goes into a reconnect loop for ever.
Web app from chrome:
CC audio just fails in connecting and goes directly back to available.
Definitely my preferred way of enjoying my music library since I dont have to turn on the telly.
Happening to me as well, exactly as described by OP. Someone plz halp!
Chromcast Audio got a new firmware 1.42.168007.
After that plex in broken (I have 3 different Plex servers at home).
Please, check your Chromcast firmware in Google Home application.
Logitech Media Server works fine with new firmware, so Plex can be fixed too !
For reference, I do not have problems casting from my Android device (Fire OS 5.6.4.0) to any of the four Chromecast audio devices I have… two running 1.42.172094, one running 1.42.168007, and one running 1.40.156414. Plex Server is running 1.16.6.1592. I can also cast when using Plex Web 4.6.2 in Google Chrome 77.0.3865.75. I can also cast from my Galaxy S10e running Plex 7.21.0.12323. I know that doesn’t solve any issues, but hopefully helps you eliminate possibilities.
Chromcast got a new firmware 1.42.172094 !
Everything is working now !
Huge.
Seems to work!
Worked for a little while. Now not working again. Am I alone or are others experiencing the same thing.
Will report back tomorrow once I have done a test.
Hey Jamie just to let you know. I rebootd all 4 of my chromecast audio devices and recreated groups. Still not working.
Plex does play on my android but as soon as I connect to chromecast audio it stops.
Same here. Really very poor timing for a Halloween party…
I am using Qmusic now. Seems to work. Not my favorite but at least am able to listen to my music.
Same here,i reboot all my devices,servers et network but nothing solve the problems
The same happens here. Nothing I tried solved the problem.
Happening here too.
