Posters stopped to apply to downloaded moview
Server Version#: 1.30.0.6486
Player Version#: 1.59.1.3398-dab42972
Unable to choose poster for downloaded movies, either manually or automatically, only thumb images available
Log file Plex Media Server.log fill of records like example below:
Dec 14, 2022 18:33:06.342 [0x7ff520a56b38] DEBUG - Completed: [192.168.107.107:56158] 200 GET /library/metadata/14745?includeExternalMedia=1&skipRefresh=1&includePreferences=1 (8 live) TLS GZIP 7ms 5170 bytes (pipelined: 8)
Dec 14, 2022 18:33:06.405 [0x7ff51bda5b38] DEBUG - Request: [192.168.107.107:56158 (Subnet)] GET /library/sections/1/all?type=1&includeCollections=1&includeExternalMedia=1&includeUserState=1 (8 live) #2f7 TLS Page 0-12 GZIP Signed-in Token (ДрегвоГастер) (HOME-PC)
Dec 14, 2022 18:33:06.406 [0x7ff51bda5b38] DEBUG - [Req#2f7] Setting container serialization range to [0, 12] (total=-1)
Dec 14, 2022 18:33:06.414 [0x7ff51bda5b38] DEBUG - [Req#2f7] Setting container serialization range to [0, 12] (total=13)
Dec 14, 2022 18:33:06.419 [0x7ff520c59b38] DEBUG - Completed: [192.168.107.107:56158] 200 GET /library/sections/1/all?type=1&includeCollections=1&includeExternalMedia=1&includeUserState=1 (8 live) TLS GZIP Page 0-12 13ms 8433 bytes (pipelined: 9)
Dec 14, 2022 18:33:06.515 [0x7ff51ae07b38] DEBUG - Request: [192.168.107.107:56158 (Subnet)] GET /photo/:/transcode?width=240&height=360&minSize=1&upscale=1&url=%2Flibrary%2Fmetadata%2F14745%2Fthumb%2F1671042786%3FX-Plex-Token%3Dxxxxxxxxxxxxxxxxxxxx (8 live) #2f8 TLS GZIP Signed-in Token (ДрегвоГастер) (HOME-PC)
Dec 14, 2022 18:33:06.515 [0x7ff51ae07b38] DEBUG - [Req#2f8] Photo transcoder: Request for url [/library/metadata/14745/thumb/1671042786?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx] (is local: 1 upscaled: 1)
Dec 14, 2022 18:33:06.527 [0x7ff51ae07b38] DEBUG - [Req#2f8/Req#2f9] It took 10.000000 ms to retrieve 123 items.
Dec 14, 2022 18:33:06.532 [0x7ff51ae07b38] DEBUG - [Req#2f8/Req#2f9] Computed media url for item 14745: https://image.tmdb.org/t/p/original/zMhPd65MVyc33898CGZkJm0rou7.jpg
Dec 14, 2022 18:33:06.532 [0x7ff51ae07b38] DEBUG - [Req#2f8] Calling back into ourselves for photo to transcode, optimizing the process (status: 302)
Dec 14, 2022 18:33:06.533 [0x7ff51ae07b38] DEBUG - [Req#2f8/HCl#c9] HTTP requesting GET https://image.tmdb.org/t/p/original/zMhPd65MVyc33898CGZkJm0rou7.jpg
Dec 14, 2022 18:33:06.533 [0x7ff51d8f8b38] WARN - [HttpClient/HCl#c9] HTTP error requesting GET https://image.tmdb.org/t/p/original/zMhPd65MVyc33898CGZkJm0rou7.jpg (7, Couldn't connect to server) (Failed to connect to image.tmdb.org port 443: Connection refused)
Dec 14, 2022 18:33:06.534 [0x7ff520c59b38] DEBUG - Completed: [192.168.107.107:56158] 404 GET /photo/:/transcode?width=240&height=360&minSize=1&upscale=1&url=%2Flibrary%2Fmetadata%2F14745%2Fthumb%2F1671042786%3FX-Plex-Token%3Dxxxxxxxxxxxxxxxxxxxx (8 live) TLS GZIP 19ms 379 bytes (pipelined: 10)
Dec 14, 2022 18:33:06.604 [0x7ff51d8f8b38] DEBUG - [HttpClient/HCl#c7] HTTP/2.0 (0.3s) 404 response from GET https://me.plexapp.com/services/pickMedia?guid=plex%3A%2F%2Fmovie%2F5eb8f2751bcfdc003f7fd125&type=poster&media=https%3A%2F%2Fimage%2Etmdb%2Eorg%2Ft%2Fp%2Foriginal%2FzMhPd65MVyc33898CGZkJm0rou7%2Ejpg&timestamp=1671042786&signature=6b690099a6641578c9a567819d01950fb2a8b193 (reused)
MODERATOR: Post removed
User contacted.
and what is characteristic - 18 days of silence on the problem, but they stood up for the pigs in a couple of minutes
@Dregvodaster
I normally receive notification for Plex Media Server - Linux tags
I don’t know why I didn’t receive yours.
If you look around the forum, you can ping any of us (or me) by @chuckpa in your post.
I look at your account.
I see 2 servers.
one has not been seen in a month
the other (NAS) was seen about a day ago
yes, that’s right - NAS server are the main one at home
and anyway - found that images download restricted by country in cloud:
ā€œThe Amazon CloudFront distribution is configured to block access from your countryā€
presume you will not be able to fix it anyway
PS. not sure why it still using Amazon CloudFront even if KinoPoisk Plugin used - [RELEASE] Кинопоиск (агент)
thought that kinopoisk website would be used to get images in this plugin config
I will forward this to the web services folks.
If you have PMS access, there’s NO reason to not have the posters
can you download your logs for me so I may present them to the team?
They’ll be able to trace better with all the timestamps.
Plex_logs.zip (584.5 KB)
Logs attached in zip
Please check around the date as per logs record:
Dec 14, 2022 18:33:06.533 [0x7ff51d8f8b38] WARN - [HttpClient/HCl#c9] HTTP error requesting GET https://image.tmdb.org/t/p/original/zMhPd65MVyc33898CGZkJm0rou7.jpg (7, Couldn’t connect to server) (Failed to connect to image.tmdb.org port 443: Connection refused)
Still not able to open this link
@Dregvodaster
Please turn on DEBUG logging (save after you change it)
INFO/ERROR logging isn’t enough here.
We need to see more info than this:
Plex_logs_debug.zip (150.6 KB)
Set logging to debug level and made few attempt to change poster
Here’s one of example (interface in RU locale):
Choosing movie on the left
Clipboard01
Choosing new poster
After saving with new poster, it doesn’t shown, but turned blank
Clipboard03
With help of @ChuckPa found that there’s is problem with Kinopoisk plugin, so nothing to fix in Plex
