Pride and Prejudice TV Mini Series
I know there have been several conversations about this specific series, but nothing I have found about the issue I have. I ripped the series from a DVD which comes in two parts. I cannot get Plex to recognize the two parts no matter what I do to the naming. The logs show that the folder and files are there, but no action taken on them. I can add them to the movies section, and it shows up, but without proper tags. Do I have to break the two parts into the 6-7 episodes or is there some way to make this work correctly? I have been trying for quite some time to get this to work and my OCD would like Plex to recognize the title correctly :slight_smile:
Server Version#: Windows 10 : 2004
Player Version#: Version 4.34.3
Aug 16, 2020 09:45:33.666 [7164] DEBUG - Scanner: Processing directory D:\Media\TV Shows\Pride and Prejudice (parent: yes)
Aug 16, 2020 09:45:33.668 [7164] DEBUG - Directory had 2 files, database had 0 files, can’t skip.
Which one?
https://www.thetvdb.com/search?query=pride+%26+prejudice
I:\Science Fiction\
......Pride and Prejudice and Zombies (2016) [1080p x265]\
...........Pride and Prejudice and Zombies (2016) [1080p x265].mkv
OR
I:\Science Fiction\
...........Pride and Prejudice and Zombies (2016) [1080p x265] - pt1.mkv
...........Pride and Prejudice and Zombies (2016) [1080p x265] - pt2.mkv
OR
A TV Show Library Folder\
.....Pride and Prejudice and Zombies\
........Season 01/
..............Pride and Prejudice and Zombies - S01E01 - pt1.mkv
..............Pride and Prejudice and Zombies - S01E01 - pt2.mkv
:smiley:
Plex Media Server Version? See Authorized Devices
There are several versions of that show. Which one do you have?
Please show your current directory structure and file names for the show.
Have you tried Multi-Episodes in a Single File naming?
Your Media -> TV Show Files (Naming & Organizing) -> Naming & Organizing Your TV Shows
Pride and Prejudice from 1995 has six episodes. If you are only getting two from your DVD then you need to look at how you are ripping it.
I have it set as below and it is detected and matched perfectly.
If you are referring to the 1980 mini-series it only has five episodes but the same structure should work fine with 1980 substituted for 1995.
TV Shows <- The TV library points here
_______Pride and Prejudice (1995)
____________Season 01
__________________Pride and Prejudice (1995) - s01e01 .mkv
__________________Pride and Prejudice (1995) - s01e02 .mkv
__________________Pride and Prejudice (1995) - s01e03 .mkv
__________________Pride and Prejudice (1995) - s01e04 .mkv
__________________Pride and Prejudice (1995) - s01e05 .mkv
__________________Pride and Prejudice (1995) - s01e06 .mkv
Sorry, it’s the 1995 BBC miniseries with Colin Firth. - I’ll take a look at some of the suggestions and get a screenshot of my current folder structure. I have tried about 15 different ways.
The DVD set came with two disks. The disk version I purchased is not divided into episodes. I use MakeMKV for all of my rips since I prefer the native formats. There were only two parts on those two disks. I haven’t spent a lot of time researching other tools because I haven’t had issues with anything else I have ripped.
Then do yourself a favor:
After you name it like this:
https://thetvdb.com/series/pride-and-prejudice
.......Pride and Prejudice/
..........Season 01/
............Pride and Prejudice - S01E01-03.mp4
............Pride and Prejudice - S01E04-06.mp4
… don’t rip the big files to save time… you won’t be happy… nobody else is.
and if those really are MP4 files:
Multi-episode naming works, but read the caveats in the documentation (see my earlier post). You’ll probably be happier if you split the files into individual episodes. Splitting is straightforward using MKVToolNix.
If you use makemkv to rip the discs, look out for chapter markers in the files. They might have been set exactly at the episode boundaries. Which makes it quite convenient to split the files: [HowTo]: splitting multi-episode files with MKVtoolnix GUI
The Multi-Episode in a Single File solved my problem. Thank you so much for this. I thought there was a way to do it, but could never quite get the naming correctly. Once I applied that naming, it came right in. Thank You!
Glad it worked. Be aware of the caveats. Namely, “but playing any of the represented episodes will play the full file.” It is really easy to split the files into individual episodes using MKVToolNix, especially if they’ve chapter markers. See the document @OttoKerner linked.
Screenshot (160)
