Problem adding to a collection with a phrase name
I have a reasonably large collection of music videos and recently thought I should assign them to collections based on artist name. So I went through and put e.g. all my David Bowie videos into a “David Bowie” collection, and I was just about to post here asking how I could bulk change all of them so the collection was called “Bowie, David” when I discovered that collections have a sort field. Yay. That problem’s sorted :slight_smile:
However… I also have many videos where the artist name is “Emerson, Lake & Palmer” but when I try to add that tag to a video it breaks at the comma and assigns the tag “Emerson” instead. I could edit the collection name to that of the group, but whenever I try to add a second video to the collection it will force me to put the video in “Emerson” instead.
Is there a trick I’m missing here? Or are commas OK in sort names but disallowed in collection names?
I’ve been checking this on my system… this seemed to work fine, e.g. for „Family Guy Trilogy: Laugh It, Up Fuzzball!“
Edit: let me verify if I’ve used this as the actual tag or if I renamed that collection after creating it.
Is there already a same-named (dumb) collection? (Or was it just recently deleted?)
Make sure you are using the hosted web app https://app.plex.tv
Bonus trick:
The latest update of Plex Web has added some major updates to collections (currently only available via the hosted web app → hence otto‘s link, or via The Plex for Mac desktop client v1.31.0+).
This version has introduced a new section in the context menu of your media where you can e.g. pick ... > Add to > Collection. From that dialog you can pick an existing collection or create a new one. There, entering a comma won’t limit the tag name.
That sounds good. My library is hosted on a NAS and I am accessing it in Chrome on Win10/64 through server:port/web/index.html; I’m not sure if that counts as the web app or not. Settings > General says I am running version 4.54.5. I have version 1.22.2.4282-6000 of the media server installed on the NAS.
As a temporary workaround I just dropped the comma, which at least lets me add to the correct collection without truncating the tag and starting to add a second one.
Those different versions and their names can be confusing.
  1. „Hosted“ refers to the version of Plex Web made available via Plex‘ own servers → http://app.plex.tv/desktop
  2. „Bundled“ refers to the version of Plex Web installed locally on your server → http://[PMS IP address]:32400/web
  3. To make things a bit more complicated there’s also a version of Plex Web used in the desktop client „Plex for Mac/Windows“
Technically both (#1+2) will be loaded into your browser and connect to your servers/libraries from there. The bundled version is usually a few releases behind.
