Problem mounting external drive again to Raspbian
I installed Plex Server in a Raspberry Pi and was using an external drive so the server can see my content. While updating it my Pi, I made an error and it crashed. I since reinstalled Raspbian and deleted everything. I tried to do the same tutorial to setup the external drive (this one: https://forums.plex.tv/t/using-ext-or-ntfs-drives-internal-or-external-on-linux/198544) but the system is showing this error. I deleted and formatted the drive but im still seeing this error, what could I do? Apperatently the disk wants to mount to the same it was mounted before I reinstall the OS but know I can’t see it when I use df in termal.
You are definitively not using that tutorial :smiley: You are not supposed to mount the drive within the Desktop Manager but with an entry in /etc/fstab.
However, the error stems from a recent kernel update. Just reboot your system and exfat will be available again.
