Problem PMS no options in language Menu when creating library
Hi I have a problem with my plex Media Server since I installed the last two versions I have encountered a problem in the Minù films and TV series in the sense that when I go to enter the language my media the menu is empty appears to be empty play the contents of the titles already recognized OS windows 7 sp1 help me please
Tommaso Antonucci
Is that the name of the film?
sorry I wanted to write menus
Are you on a VPN or using other network tools? Do you have any browser extensions/plugins installed? Can you try in an incognito/private browser window
If you restart the server it will reappear
Thanks for the help you give me
Even if I send the browser incognito the screen remains the same with the same problem
I do not use active VPNs at the moment and neither configured on the pc
I have disabled ad block
I insert a screenshot of my extensions on the browser.
the problem persists if I restart the pc
I add one more information in previous versions once PMS was installed it made me immediately see the screen with the Plex logo at the first start when I opened browser from http://127.0.0.1:32400/web/index.html#!/ while this time I got a blank (empty) page when restarting the PC the initial screen appeared and I noticed the other problems that have already been indicated to you
I also remember that I can no longer play the contents
