Hi:
Wondering if anyone else has or has seen this problem: While syncing item from the Music library to an iPhone it works for a bit then drops into “Waiting on Server” and it will sit like that till I pres the “Sync” button on the iPhone. Once I do that the synchronization process kicks off again but eventually it will stop forcing me to hit the “Sync” button again.
I do not know if this is a network problem, a Plex Server Problem version 1.0.0.2261 (please do not tell me to upgrade unless you are certain the problem is with this version and the newer one has fixed it, and my iPhone is running Plex for IOS version 4.2.
On the iPhone I have disabled Auto-Lock and from what I can see all other low power options that might affect Wi-Fi but the phone is on it charger cable and is and always has been at 100% during the sync.
I have zipped and enclosed the current log file. If others are required let me know.
Randy
