Problem to enable subtitles
Server Version#: 4.35.1
sorry for the mistakes, i’m not english
i’ve spent hours looking for a solution as i defintly know that the problem is usually between the chair and the screen … but… i need help
I’ve been using PMS for years on my Synology NAS and now i cannot make it work well on my Nvidia Shield:
Even if (i think) i did a good subtitles configuration, i still don’t have anything…
I’d like to have the automatic subtitles download. I’m not using External SRT
  • In Agents > Movies > Plex Movies, i activated opensubtitles.org and then plex movie. I registered log in and opensubtitles password
  • In Languages, i chose the automatic audio and subtitles selection with english for audio and french for subtitles (always activated)
When i open a movie, i don’t have any option for the subtitles. I cannot select anything. it’s just written “none”. For years i used PMS on my synology and it was working perfectly
Please, help…
If you are using external SRT subtitles in the same folder as the movie/show, enable Local Media Assets. Then refresh the metadata for the library. See Adding Local Subtitles to Your Media.
If the option to download from opensubtitles.org is not working, see Troubleshooting Subtitles.
Using Subtitles
Thank you for your answer. I’m not using external subtitles
I’ve downloaded and read the text file of the log.
I keep having this kind of message:
“2020-06-14 19:19:21,693 (26f6caf4f0) : INFO (init:116) - Looking for match for GUID 7ff08dee4a840c64 and size 2149598548
2020-06-14 19:19:21,791 (26f6caf4f0) : INFO (init:126) - Found nothing via hash, trying search with imdbID: 0390808
2020-06-14 19:19:21,858 (26f6caf4f0) : INFO (init:223) - No subtitles available for language fre”
And this is weird to:
Cannot read model from /storage/48EC3537EC35211C/Android/data/com.plexapp.mediaserver.smb/Plex Media Server/Metadata/Movies/c/327f5802fc6986a3a4016a28abaf0c507ec5a59.bundle/Contents/com.plexapp.agents.opensubtitles
I’ve tried with something like 100 movies. no subtitles while they have the good name / picture and stuff.
before i was using PMS on my synology NAS (with the same movies) and i never had this problem. I’m using a Nvidia Shield now
Can i have some help please?
Plex Media Server Logs_2020-06-14_19-32-20.zip (1.8 MB)
Help please…
I’ve never had much luck with opensubtitles.org, and no idea how to troubleshoot. Hopefully somebody can assist.
There is a limit of 200 / 24 hours. Maybe that is coming into play? See this post for more info.
Fetching Internet Sourced & Using Your Own Subtitle Files mentions additional places you can manually download subtitles.
OMG, problem solved because of a recent update of Plex; I’m so happy with that.
i’ve just found out that now, it’s possible de download subtitles straight from the movie page and for me, it works perfectly!
