Problem with Extras naming
Hey everyone,
I added a deleted scene as an extra for one of my episodes using the local files method described here:
https://support.plex.tv/articles/local-files-for-tv-show-trailers-and-extras/
Filename: Breaking Bad (2008) - S03E01 - No Mas {1080p}-deleted1.mkv
The extra does show up under the episode, but the display name Plex chooses is terrible. I want it to change the name.
Has anyone figured out how to rename the extra that shows up in Plex?
Assuming the file name of the episode is:
Breaking Bad (2008) - S03E01 - No Mas {1080p}.mkv
This will work:
Breaking Bad (2008) - S03E01 - No Mas {1080p} - Deleted Episode Title-deleted.mkv
That extra will be listed in Plex as „Deleted Episode Title“.
Make sure the extra title contains no dash -!!
Side note: I would suggest to place the technical gibberish in a set of square brackets to avoid Plex from attempting to use that part to recognize what show / season / episode the file represents.
Edit:
Sharing an example…
Edit 2:
I noticed I’ve got that very example of yours :wink:
Thanks a lot. The {1080p} part was also causing issues for me. After I removed it, it worked.
