Problem with "Looney Tunes"
I’ve added a new directory/library for Looney Tunes cartoons, and have added many files for each cartoon there. I’ve used the naming convention:
Looney Tunes/
Season_1950/
Looney_Tunes_S1950Exx-title.mkv
The issue is that the TVDB scanner doesn’t find any of the titles, and in fact when I try to do a match on just the top level directory “Looney Tunes” it returns that it isn’t found. I know the TVDB has it, because I looked up everything in there… but not even the top level? What do I need to do?
This works perfectly at my house.
TVDB and Plex are filing for divorce (apparently), but things do work as expected IF you use the exact naming they suggest. I use FileBot so it knows no other way than to use the name they use.
However - if your system can’t use absolutely correct names - for some reason - you can add new episodes and Fix Match at the show level with the TVDB ID# in place of the name in Search Options.
72514 is the ID# - remove everything else. The ID# is found at the very first page at TVDB - in the upper right corner.
IF you do that once at the Show Level - you shouldn’t have to do it again for more episodes… if that’s happening there could be more wrong than we think.
IF you’re using the New Series Agent - good luck. I know nothing about it.
Thank you… The magic sauce was using the ID# in the search instead of the name. Much Appreciated
My problem is it’s showing seasons on android
Would you mind elaborating what you mean by that?
