I have a Problem with Movie extras showing up under version control instead of the extras tab.
All the extras have the right flags. Their are stored under D:/plexmediaserver/movies/movie_name/extras
On some movies it works just fine but on others it doesn’t.
In some cases Plex tries to look in an subdirectory that i have in the extras folder for stuff like Blueray menus and Disc openings called /blueray
See the documentation regarding trailers and extras.
If you use -trailer, etc, the file must be in the folder with the movie. If you use folders to hold the extras, the folder must have one of the supported names (Trailers, Scenes, etc).
After renaming/reorganizing, rescan the library and refresh the metadata for the movie to pick up the changes.
