Server Version#: latest
Player Version#: latest
Hi, my server works fine until today, i think the plex certificate was renewed and assign to me a bad ssl certificate:
Like you can see in the image, the token after my server ip address don’t match, so the connection is not safe…
How can i fix this? thanks!
How did you open the web app?
Does the same happen if you close the web browser, open it up again and then you go to app.plex.tv ?
I noticed you created a new plex server today. Did you assign it the same local IP address like your old server had?
this morning server works fine, this afternoon server does not work, so i restart the server, reboot the machine, etc. And i enter to localhost:32400 and i don’t know why, the server says is new server :S, but i reload the page and the first setup page dissapears. I don’t know why.
I tried with incognito mode, and with desktop windows player app and didn’t work. i also try with app.plex.tv
And i try to reinstall PMS (without deleting old PMS), just like and update, and not working.
i already do that.
And i also use this https://github.com/ukdtom/ClaimIt
Not working.
when i restart the server i get this error:
Oct 26, 2019 18:51:03.295 [0x774036dfe700] DEBUG - HTTP requesting POST http://127.0.0.1:32600/devices/discover
Oct 26, 2019 18:51:03.296 [0x774036dfe700] ERROR - Error issuing curl_easy_perform(handle): 7
Oct 26, 2019 18:51:03.296 [0x774036dfe700] WARN - HTTP error requesting POST http://127.0.0.1:32600/devices/discover (0, No error) (Failed to connect to 127.0.0.1 port 32600: Connection refused)
Oct 26, 2019 18:51:03.297 [0x774036dfe700] DEBUG - DVR:Grabber: Failed to retrieve device data
ok, i solve the problem.
1º Stop the PMS Server.
2º Do backup of /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Preferences.xml
3º Delete Preferences.xml
4º Star PMS again, enter to 127.0.0.1:32400/web and just setup the server
With this, i didn’t lose any library data, the database file didn’t changes and the server is the same that before stop works.
thanks for all!
A wrong port of 32600 may have been the issue here. It should be 32400.
Hi, I am a newbe to Plex, but have the same problem as you, so i deleted the Preferences.xml, restarted PMS Server, restarted my Synology NAS and still have no connection and as far as I can see I have the same client certificate (didn’t write the old one down) as before, but with a new timestamp.
What have I misunderstood?
Kurt
