Unable to acquire SSL certificate
Server Version#: 1.30.0.6486
Server is on a Windows 10 Pro machine
My server restarted during the night and since then, I’ve not been able to connect to Plex on any device other than the host, either on the local network or WAN.
I believe it is due to the SSL certificate (I am not using a custom one) however I am not entirely sure. With secure connections set to preferred, I can connect through the web app (on LAN and WAN, but still not through any iOS/Plex HTPC/Android TV apps (on LAN or WAN).
I am getting two CERT errors which are making me think the SSL is the issue.
Section of the PMS log
Dec 23, 2022 16:33:06.266 [6176] DEBUG - [Req#fe] CERT: Forcing refresh.
Dec 23, 2022 16:33:06.267 [6176] DEBUG - [Req#fe] CERT: Certificate did not exist, fetching a new one.
Dec 23, 2022 16:33:06.267 [6176] DEBUG - [Req#fe/HCl#542] HTTP requesting GET https://plex.tv/api/v2/devices/81f6420fb6bc0f1eeeee8183312062b4ec9f1dfa/certificate/subject
Dec 23, 2022 16:33:06.544 [5052] DEBUG - [HttpClient/HCl#542] HTTP/2.0 (0.3s) 200 response from GET https://plex.tv/api/v2/devices/81f6420fb6bc0f1eeeee8183312062b4ec9f1dfa/certificate/subject
Dec 23, 2022 16:33:06.646 [6176] DEBUG - [Req#fe/HCl#543] HTTP requesting PUT https://plex.tv/api/v2/devices/81f6420fb6bc0f1eeeee8183312062b4ec9f1dfa/certificate/csr?reason=missing&invalidIn=0
Dec 23, 2022 16:33:06.727 [5052] DEBUG - [HttpClient/HCl#543] HTTP/2.0 (0.1s) 429 response from PUT https://plex.tv/api/v2/devices/81f6420fb6bc0f1eeeee8183312062b4ec9f1dfa/certificate/csr?reason=missing&invalidIn=0 (reused)
Dec 23, 2022 16:33:06.727 [6176] ERROR - [Req#fe] CERT: Error acquiring new certificate: Failed to upload CSR: 429, <?xml version="1.0" encoding="UTF-8"?>
<errors>
  <error code="1003" message="API rate limit exceeded" status="429"/>
</errors>
Dec 23, 2022 16:33:06.734 [0736] DEBUG - [CERT] MyPlex: Last published value didn't change, we're done.
Dec 23, 2022 16:35:06.736 [7456] DEBUG - [Req#fe] CERT: Forcing refresh.
Dec 23, 2022 16:35:06.737 [7456] DEBUG - [Req#fe] CERT: Certificate did not exist, fetching a new one.
Dec 23, 2022 16:35:06.737 [7456] DEBUG - [Req#fe/HCl#544] HTTP requesting GET https://plex.tv/api/v2/devices/81f6420fb6bc0f1eeeee8183312062b4ec9f1dfa/certificate/subject
Dec 23, 2022 16:35:06.992 [5052] DEBUG - [HttpClient/HCl#544] HTTP/2.0 (0.3s) 200 response from GET https://plex.tv/api/v2/devices/81f6420fb6bc0f1eeeee8183312062b4ec9f1dfa/certificate/subject
Dec 23, 2022 16:35:07.076 [7456] DEBUG - [Req#fe/HCl#545] HTTP requesting PUT https://plex.tv/api/v2/devices/81f6420fb6bc0f1eeeee8183312062b4ec9f1dfa/certificate/csr?reason=missing&invalidIn=0
Dec 23, 2022 16:35:07.167 [5052] DEBUG - [HttpClient/HCl#545] HTTP/2.0 (0.1s) 204 response from PUT https://plex.tv/api/v2/devices/81f6420fb6bc0f1eeeee8183312062b4ec9f1dfa/certificate/csr?reason=missing&invalidIn=0 (reused)
Dec 23, 2022 16:35:07.168 [7456] DEBUG - [Req#fe/HCl#546] HTTP requesting GET https://plex.tv/api/v2/devices/81f6420fb6bc0f1eeeee8183312062b4ec9f1dfa/certificate/download
Dec 23, 2022 16:35:07.244 [5052] DEBUG - [HttpClient/HCl#546] HTTP/2.0 (0.1s) 202 response from GET https://plex.tv/api/v2/devices/81f6420fb6bc0f1eeeee8183312062b4ec9f1dfa/certificate/download (reused)
Dec 23, 2022 16:35:08.245 [7456] DEBUG - [Req#fe/HCl#547] HTTP requesting GET https://plex.tv/api/v2/devices/81f6420fb6bc0f1eeeee8183312062b4ec9f1dfa/certificate/download
Dec 23, 2022 16:35:08.317 [5052] DEBUG - [HttpClient/HCl#547] HTTP/2.0 (0.1s) 202 response from GET https://plex.tv/api/v2/devices/81f6420fb6bc0f1eeeee8183312062b4ec9f1dfa/certificate/download (reused)
Dec 23, 2022 16:35:09.322 [7456] DEBUG - [Req#fe/HCl#548] HTTP requesting GET https://plex.tv/api/v2/devices/81f6420fb6bc0f1eeeee8183312062b4ec9f1dfa/certificate/download
Dec 23, 2022 16:35:09.395 [5052] DEBUG - [HttpClient/HCl#548] HTTP/2.0 (0.1s) 429 response from GET https://plex.tv/api/v2/devices/81f6420fb6bc0f1eeeee8183312062b4ec9f1dfa/certificate/download (reused)
Dec 23, 2022 16:35:09.395 [7456] ERROR - [Req#fe] CERT: Error acquiring new certificate: Failed to retrieve cert from plex.tv: 429,
Dec 23, 2022 16:35:09.402 [1256] DEBUG - [CERT] MyPlex: Last published value didn't change, we're done.
Other topics I’ve seen with similar cert issues make it seem like a Plex employee needs to reset the cert on my account?
Thanks in advance
That error means your server contacted Plex too many times to get the security certificate. Did you try unclaiming/reclaiming your server multiple times in a row? That will initiate a block.
Turn off PMS, go to lunch/dinner/snack break for an hour or 2, come back and turn on PMS.
Thanks, turning it off for a couple hours seems to have let it redownload the SSL cert and all seems to be working.
