Server Version#: 1.14.1.5490
I am running plex server on my Nvidia Shield. it was working fine when i last used it in June. Since then the epg guide is not available in canada i manage to get xmltv listing instead. The first import was working fine. But when i want to import a second updated xmltv file, it stops working correctly. So i remove my silicon dust Hd Homerun tuner in the plex configure and try to add it again. But when i specify the xmltv file and after i always got an error saying there was a problem with your DVR, please try again.
Anyone has this problem ?
The path i gave for the xmltv file is /sdcard/guide.xml and the file is copied directly at the root of the share /shield/internal
